Removing the W203 Wing Mirror Casing
CrazeUK
Manchester
C220 CDI 2001
Make: Mercedes
Model: C220 CDi
Body Type: W203
Transmission: Automatic
1. Push the mirror towards the back of the car firmly. It feels like it shouldn’t be pushed but it does.
2. Try to push as far as you can, I used my body weight to hold it back as it has a very powerful spring.
3. Look inside the folded mirror and you will see some brass bars, look on the inside of the mirror casing and you will see a silver clip, this needs to be pushed out with a screw driver towards the body of the car, use the edge of the Mirror casing for leveraged. You will hear it click
Failing to do the following steps carefully will hurt you!!!!!!
5. Now keeping the mirror folded slightly push. BUT NOT ALL THE WAY. The Casing should slide.
6. Now let the mirror relax back to its natural position and pull off the casing.
7. Voila.. its done!!!!
Mercedes-2010
Staffordshire GB
Mercedes C350 AMG Sport (2013)
If you have electrically folding mirrors then just close them in without the need to wrestle with the mirror body, easy peasy, I changed one of my indicator strips only last week...
Great How To
M80
Derbyshire
The question of how to is asked often so this should be useful to many.
