Replacing old w203 stereo
norman1988
C class 2005 C200 kompressor
Hey guys I wanna replace The old factory stereo in my merc w203 space with one from Ebay like a normal 2 din Bluetooth one would it just be a case of swapping them over or does the stereo have to be screwed in to work as all images I see have the screw holes on it??,
Thanks.
AnthonyUK
Alton, Hants
C240 estate 2002
There are units designed specifically for the w203. Try searching on ebay for 'w203 android head unit'.
They should integrate quite well with steering controls etc.
N
norman1988
Cool many thanks I will do that.
JBell
Torquey
C350 CDi Estate (GAD Edition)
YouTube is your friend
N
norman1988
So if I get the right trim ie a universal 2din frame for my new stereo will it fit regardless apart from it having to match the same frame size as the din??
AnthonyUK
Alton, Hants
C240 estate 2002
When I changed from Audio10 (DIN 1.0) to COMAND (DIN 2.0) I didn't need to change any trim.
If the unit is a W203 specific item you should just be able to remove the single DIN item and storage tray and fit the double DIN unit. I assume they will come with wiring adapters but check.
You will only need a facia if fitting a standard double DIN unit e.g. the rectangle type.
N
norman1988
How bout if i was just to buy a like 6.1 inch Bluetooth unit for satnav with Bluetooth etc u think it would fit?
N
norman1988
Ok it dose seem that almost any 6.1 - 7inch will fit the area dose it just depend on that you have to get a specific one that fits it or can get a din frame that matches the radio shape??
AnthonyUK
Alton, Hants
C240 estate 2002
I think the specific ones will not only fit but also be easier to install/integrate with the existing cables and antennas.
N
norman1988
Ok cool many thanks would it be possible thou?
AnthonyUK
Alton, Hants
C240 estate 2002
Yeah. Most are CANBUS compatible now. As long as you don't have the optical amps (MOST) then it is straightforward.
You'll likely also require a GPS antenna which are £10ish and can be slid in under the grill on top of the dash.
Also consider that most of the earlier ones were underpowered and lacked RAM so are almost unusable now so it might be a false economy buying a low cost item if it isn't well specced.
N
norman1988
Ok many thanks il try get one with a gps antenna then many thanks for your help.
www.ckinsurance.co.uk
