Running Lights on a 230 (same as many others)
Its never easy adding things like driving lamps without them looking stuck on or very wrong and not suiting the car at all. I have been watching Ebay for over 12 months now and all are too big, mainly the length is too long, but 2 weeks back a seller had these flexible self-adhesive lamps with just 6 LED’s. This is the appearance of them fitted to my SL (09model) but near enough the same for most 230’s.
To start with it’s a matter of removing the grills from the fog lamps, most just unclip from the bumper. As there is nothing much to stick them on, I made up a plastic backing from a side of an old TV case. In this case just 20mm wide, and the length to suit the lamps. I screwed them to the grills with 2 2.5mm countersunk screws. Aluminium would do just as well painted black.
The next job was getting access to run the wires to the drivers side only in my case, so off with the grill (please ask if you want to know how to remove the grill) and the two fog lamps. It was now a matter of pushing a draw wire through to pull the thin cables through.
You will need an auto switch circa £10 Ebay so that the parking lights turn them off. In my car it was a dream to do as the wiring is all in trunking. There is a good ground terminal in front of the drivers side fuse box, the rubber grommet where all the wires go in is split, and the main plus just needs an ignition on point. Again a spare one was found and I connected up via a 2 amp fuse that just tucks down into the side of the box. The tiny switching box is in a pocket behind the head lamp
Next you need to connect the wire to the side lamps, in my case Grey/black was laying in the trunking, so I just joined to it and replaced the trunking lid.
They look OK to me and not too stuck on
To summarize just need the pair of lamps approx £5. they come with 6, 9 or 12 LED’s I bought 2 sets so I have spares, a switch box. Just join the output of the box to both running lamps. For the input, just black to ground, red to ignition on feed, and the switching wire to the side lamps.
I will do my CL500 next and add some more
If any member wants to know how to take parts off their car to do the same please ask in the thread.
  • #2
Will a nice mod please pop this in the DIY section leaving this post for questions.
Thank you.
shine
Hampshire
CL 500.W216 + C300 Coupe AMG Line 2018
I need to put something like this on my CL 216, I have the AMG body kit would this work
I have the same with AMG body kit and am doing withing the next 2 weeks.
They will mount mainly out of sight under the lip over the fog lamps.
I will do the whole thing into a DIY with pictures.
shine
Hampshire
Thanks Malcolm, will you be using more LED lights than on the SL?
Can't wait to see the photos, will probably get the team at MBS to sort it for me..Thanks Cole!
Cole@MBS
www.mbssouthampton.co.uk
EErrrr, no probs Mike...............i think................
The Cl will take the 8 lamp version just at 16cm long.
I can give Colin the 2.5mm nuts and screws and possibly the backing strips, together with the pin outs in the main fuse box, that will save 7 hours searching in WIS :rolleyes:
shine
Hampshire
Cole, you guys are amazing if anyone can do it you guys can. Will be interesting to see how Malcolm puts this one together.
shine
Hampshire
Thanks Malcolm, any help will be appreciated, got to bring out the best in the beautiful CL.
You could get a very long version, but it would show too much. I tried others last year and gave up as they all looked tacky and not for the CL, the trick is to lose them so not obvious.
shine
Hampshire
I agree it's got to be right for the CL.
So that you can order the parts, I can fit one and take a picture to see if you like it. I will do this shortly.
shine
Hampshire
Thank you Malcolm I appreciate your response.
  • #17
Excellent read - the look is very factory to me!
That is the most important bit, rather than stuck on, the 216 with longer lights will look even better, a photo later in the day.
  • #18
This is what it would look like on the 216 with a 8 lamp unit, sorry its a bit on the dark side, but the sun was too bright.
C16RKC
Wisbech
www.youtube.com
2003 CL500, 2007 S320CDi
Neat - you can see they fit just right.
Very good stealth install, other road users would just assume they were a factory fitment.
  • #20
True, and there are not many CL's around to compare with.
www.ckinsurance.co.uk
