Running Lights on a 230 (same as many others)
  • #41
I believe you just break the seal, another 202 owner would know better.
The glass is sold on its own, you could put a long one in there.
bigasotonuk
Southampton UK
C43/55 AMG 1999 / C230K 1997
Be aware the lower apertures in the bumper of a non AMG 202 are brake cooling ducts, I would put them in the bottom of the headlight as Malcolm has suggested. Was going to put some there myself, but was never happy with what light fittings were available at the time.
bigasotonuk
Southampton UK
Regarding taking the headlight lenses off of a 202: There were two types of Headlight fitted to the 202, Valeo on early cars and Bosch on the later ones, the change came around the time they facelifted the model in late 1997.
To identify between the two, the Valeo/earlier cars had a single cover at the back of the headlight, whereas the Bosch item had two round covers.
The Bosch lenses are easier to remove, just pop half a dozen or so clips around the edge the headlight, this can be achieved if carefull with the headlight still fitted in the though fiddly.
The Valeo ones are different in the fact though they still come off, the lenses have a plastic surround with built in clips that just need pushing down and pulling the lense at the same time though from memory this headlight has to be removed completely from the car to remove the lense.
When removing the lenses it will definetly stick to the seal, this will damage it due to the material it is made of, and new I thought they were expensive.
darkchild101
Edinburgh
C250 TD/1997/2.5litre
:Oops:
Oh dear, looks very complex. And do the lights stick on or how do they stay in place?
  • #45
  • #46
Some members though that my 230 running lights were too short, so after much thought I removed the 2 grills holding them and worked out that I could cut away the raised part and have them sitting flush with the grill, this enabled me to fit the 8 lamp version and so much better, they look part of the car and not stuck on. There was no way that I was going to use the fog lamps as no mercedes that I know of have round running lights.
Gkinghorn
Bournemouth
E350 CDI Cabriolet - 2011
Very nice. . As always
Sent from my SM-P605 using Tapatalk
Christian
Horsham
w205 AMG Edition, Panasonic washing machine :)
Can I have these fitted on my w164 as DRLs? Would be nice.
Where did you buy from ? Thanks
  • #49
Dead cheap on Ebay, they come in 6,8,10 or12 leds under £10 pair, all it needs is the switch, also Ebay about £12.
Christian
Horsham
Any ebay item no's?
Pitsmoor Col
Sheffield
2014. W205, C Class C220. Diesel Blutec Automatic Saloon.
What a great bit of customising, I would love to do something similar to my C class. Just a thought, have you tried getting hold of some Red ones for the rear ?
  • #52
Never seen any as of yet.
TamOshanter
U.K
c250
hi Malcolm
I sent you a PM. My car is a w202 where do i connect the switch for the lights. I mean which is the ignition feed on my car? A pic would be great
  • #54
So sorry Tom I missed that PM :( Being a 250 I take it it is a diesel.
I am short of time this week, please PM me with the cars first 0 VIN number and I will check as soon as I can.
TamOshanter
U.K
c250
Here you are Malcolm WDB2021282F604475
So with this set up the drls switch on automatically once i start the engine or i have to turn on side lights?
  • #56
With the right auto switch yes on with ignition and off if you turn the lamps on. I am away from home for a few days, please PM me again and I will see to it when I get back home.
  • #58
I hope to this evening all going well.
  • #59
Hi Malcom
Have you managed to check please
Fuse 27 in fuse block C, this is the steering lock, use a piggy back fuse and it is ignition on live.
Your dimming turn off wire you wire to one of the side lamps
TamOshanter
U.K
c250
Thanks could you simplify please. What do I do
