rusty stains under cill slk
paulwith
I have recently noticed rust coloured stains on the floor under the nearside cill of our 92 slk 320. If I pour water onto the screen or roof it finds it's way out through several small holes under the cill and through the cill fixing screws.I'm sure this is normal,the problem is it seems to be gathering surface rust on the way and staining my nice new drive.Does anyone know a cure,is it neccessary to remove ther cil,if so how is it done?
Many thanks.
G MAN
380 slc 1981
Hi Paul not familiar with your model but my experience is that your water test should ,if no problems, result in a definite spout of water of the same volume emerging from the cill through the drain hole/pipe. Your desription suggests that the drain is blocked & water is seeping through some corrosion which may be hidden under the cover. Water does gather with mud etc & rust develops here rapidly. Check the Russian site
http://www.detali.ru/cat/oem_mb0.asp?TP=1 to see where your drain gullies/routes & fixings are for any cover are.
A common mistake is that a previous repair may have welded up the rusty drain exit by mistake resulting in the water being trapped & seeping through anywhere it can.
Sometimes a blockage can be removed with welding rod(soft bendy probe) & judicious use of an airline. Best to work initially from the bottom up as you don't want to puncture or blow any drain tube off
