Separating coolant and oil
Hi all
I used my Pela oil sucker as part of the ridiculous bleeding procedure on the S class. It invovles moving 20liters of coolant through the system to get rid of air.
I am now left with a bucket of new coolant with a film of oil on the top.
Any thoughts on the easiest way to separate it?
flowrider
SL500 (R230)
Hi all
Could you syphon the oil off the top?
  • Moderator
I night try and use the sucker again to pull it off the top.
I had thoughts of trying to suck it from the bottom but removing the oil seems easier.
om613
london
S202 C250TD, S123 240TD
I'd float a few tissues on top, then remove.
  • Moderator
Frontstep
T210 320cdi
Kitchen Roll that stronger stuff .
There will be very little oil and it probably won't do any harm reused as is.
  • Moderator
Used some tissue and the sucker to get most of the oil out, now safely in bottles. Much better! Thanks
