Service due warning....
Sheffield 61
E220 estate CDI 2010
Hi all....
Bit of advice needed please....
I've got a SERVICE DUE indicator warning on the dashboard of my 2010 Mercedes e220 blue efficiency estate.....
Any advice as to how to turn this off would be much appreciated.....
Regards,
John in Sheffield....
sl500amgsport
Essex
SL500 2014
Step 1 – Turn ignition to position "1"
Make sure all the doors are closed, then press the ignition button once to place it in position "1."
Step 2 – Scroll to the "Trip" option
Press the left or right system selection button until the menu choice "Trip" is highlighted in the multi-function display.
Step 3 – "Accept" a phone call
Hold the "Accept Phone Call" button located on the right side of the steering wheel. While holding the button down and within five seconds, press and hold the "OK" button on the left side of the steering wheel.
Step 4 – Press the scroll forward button
Repeatedly press the scroll forward button until "ASSYST PLUS" is highlighted and stored, then confirm selection by pressing the "OK" button.
Step 5 – Restore to "Full Service"
Press the scroll forward button until "Full Service" is highlighted. Confirm the selection by pressing the "OK" button.
Step 6 – Reset the service indicator
Press the scroll forward button until "Conf. Full Serv." is highlighted. Confirm the selection, and reset the service indicator by pressing the "OK" button. Once the service indicator is reset, place the ignition back to position "0."
Sent from my SM-G988B using Tapatalk
DSK
CLS 320 CDI, S350 Bluetec
Service the car as required.
Reset the indicator as above or with a diagnostic tool.
That’s how I read it… car needs a service, switch of the warning and the car is serviced
EmilysDad
Bury Lancs
ML350
I credited John in Sheffield with a bit of common & assumed the car had been serviced but the service warning hadn't been reset
mioba
Nottingham and Köln
Only the OP can answer if the car has been serviced.
My thoughts are “what kind of service has it had and by whom of they don’t know how to reset the service indicator”… if it was by any form of garage I’d be very wary…
EmilysDad
Bury Lancs
ML350
EmilysMum's C3 came back from service at Citroën themselves with the service indicator on :oops:
sl500amgsport
Essex
SL500 2014
Take a pic of the indicator and ask for a full refund "as no service has taken place", if they refuse tell them you will be posting the pic to the press as you have no proof of anything having been done ;-).
EmilysDad
Bury Lancs
ML350
it was a few years ago now
mioba
Nottingham and Köln
My thought was it has not been serviced and removing the light indicated otherwise cough cough
Sheffield 61
WOW,
So many nice replies and thank you all....
Sorry just logged back in.....
She HAS been serviced but I couldn't afford Mercedes so a mobile mechanic did it for me a month ago. Does this mean that I am stuck with this annoying issue please??....
Sheffield 61
Kind of yes....
malcolm E53 AMG
I would have expected the mobile mechanic to reset the service indicator manually?
Reset procedure above #2 or visit YouTube for a video guide
sl500amgsport
Essex
SL500 2014
"Mobile Mechanic" may not have been aware, indicator is usually reset by Star, manual procedure is a sort of backup override.....
mioba
Nottingham and Köln
Surely a reputable mobile mechanic would have some diags tool to do a service reset. A service is the most basic of maintenance tbf.
sl500amgsport
Essex
SL500 2014
Reputable and mobile are a bit of an oxymoron in this instance;-).
littlebrooklyn
SW Herts
2016 A180d
I hate how the service indicator comes on a whole month before the service is due and it's just a flipping nuisance. Ours comes on every time I start the car and I have to mess around getting rid of it, only for it to be there the next time I use the car. I'm so ticked off by it that we have booked the car in 2wks early for it's annual service & MOT even though I know that is just a short term solution :D
