SL350 central locking problem
STEc74
St Helens,Merseyside
My car SL 350 05,sons car CLK320,other cars BMW 318IS ,95, 1964 Chev Corvair Monza restoring.
This problem started last night after a run in the car,on ariving home i tried to lock the car with the fob but would not lock althoughindicators flashed as normal,tried the emergency key,this to would not lock the car but alarm activated when opened the door,further to this i can`t gain access to the boot with either switch on drivers door or key fob,the emergency key wont turn in boot lock, maybe stiff .
any advice welcome.
drmw
Yorkshire
www.autonomed.co.uk
99% certain this is the PSE pump in the boot
There is a fuse behind the driver's seat in the storage box under the false floor - it's the only 20amp (yellow) - check that first
If it's gone, then a possibility of water ingress in the boot, but best one step at a time to find the cause
Dec
Ireland.
W202
What year is the car?
Dec
Edit
Typical vacuum pump, see post#46 here… http://forums.mercedesclub.org.uk/showthread.php?p=525297
attachment.php
Dec
drmw
Yorkshire
www.autonomed.co.uk
re getting in with the key - I've always used the one from the remote itself.
It should turn in either door, so if not, then as the previous post, you need to spend some time with (initially) WD40, wiggling the key about - it will eventually turn. After if does, shoot some silicone lube as WD is not the best to leave on its own.
The boot is more of the same until the key turns. Once it does, you need both hands to get in.
Looking down on the boot lid from above, turn the key in a clockwise direction and hold it there, with the other hand, pull the boot release handle & it should open. You cannot isolate the boot lock - if the PSE is down, it's key every time.
STEc74
STEc74
Hi deck car is 2005, in the winter months the boot seems to get a lot of condensation causing metal work to be dripping wet, has stopped raining now so will have a go at openning boot,cheers will keep you posted....Steve
STEc74
STEc74
have tried freeing lock with WD working key left to right, have got some movement anticlockwise but still very stiff will not turn clockwise,does key open either way,i`m frightened of breaking the lock.
drmw
Yorkshire
www.autonomed.co.uk
the bootlock only works one way - pretty sure the doors the same.
You have to persevere - it should operate. eventually, but if it's the boot you're trying, the key on its own will not unlock or open the boot - it needs the handle pulled at the same time (turn key & hold, then pull handle) and the key (from memory) doesn't even go 90 degrees max
Did you check the fuse yet? If it's blown, it's not a good sign, but replacing it might get the system working briefly
STEc74
STEc74
Hi, checked 20 amp fuse, has blown,Should i pop in new fuse and what could cause it to blow.
Better still is to stop the water from getting in if the foam box that the pump sits in as the water can run down the cables, have you opened the drivers door yet and checked the 20 amp fuse that David talked about
If it blows again then the pump has failed, at the very least the pump needs to be removed.
Just undo the the 4 nuts holding down the roof pump and lift to 1 side, then lift the PSE pump in the foam block out and separate the two halves, the pump will unplug and so will the vacuum connectors.
STEc74
STEc74
Yes fuse has blown there are two 20 amp fuses the one in a blue fuse holderto the right is ok.
I only have the 2002 500 diagram and only 1 20 amp fuse number 171, 4th from the right
drmw
Yorkshire
www.autonomed.co.uk
I thought that too - even said so in an earlier reply on this thread - assumed I'd missed one!!
I am sure there are no changes David, if any after 06-06 I forget if there are any spares in that box, or are they all up front
STEc74
STEc74
seems like the wright fuse fourth one in just off centre
drmw
Yorkshire
www.autonomed.co.uk
as you will be trying another fuse & it may work for a while, make sure you leave the storage box lid open - it locks as well as the doors etc which means a bit of messing about to get to the fuse if/when it blows and the car is then locked!
STEc74
STEc74
  • #20
could`nt find spare fuse so called to shop,fitted fuse every thing working opened boot with fob, will check out pump will it need drying or cleaning
