What does the, cut the ears off the heater box drain do?
I assume they fixed this problem on the facelift. Or not?
exactly what i thought i was trying to say smooth roads smooth driving , no demand ,oil reaching valve block returning thru filter back to tank. demand seen ,pump unrestricted ,more flow , more oil returning to tank thru filter now back to these pumps. if eccentric, when there is little or no demand (load) the vanes tend to chatter a bit around the eccentric ring creating uneven and more wear . than when they are loaded . thus perhaps providing some explaination to issues of wear on this system, high miles v low miles failures, as i believe a pump on a car driven reasonably hard on less than perfect roads will probrably last longer than the same pump on a car poodling about on great roads. just my belief .
Absolutely, as I have said before, the problems that most often come up are one corner sinking, the rear end raising when in R. this is another reason why the wheels must be hanging down when bleeding to empty the struts as far as possible.
I'm sure we've discussed contents of struts before and eventually agreed that the struts would be empty in the compressed state rather than uncompressed with the wheels hanging down?
The rationale for this is that if a valve block is leaking or a pipe bursts the strut will collapse as it ejects most of the fluid inside it either back ti the reservoir or onto the road.
The first line above says to empty via the bleed screws with the car on its wheels so the struts will be compressed by the cars weight, not hanging.
I think I've worked out why things dont stack up for me! I've only ever talked about changing the fluid which doesnt introduce air into the system so no bleeding required and no hanging wheels.
Happy birthday by the way
But why not do it the correct way to make sure there is no air in the pipes, and change some more fluid from the pipes. We know that with the car sitting right down the struts are virtually empty.
??? Theres no air to start with and no air gets introduced so no air in the pipes. All the old fluid in the pipework gets flushed out by the new fluid entering the system.
