SL55 ABC mind of its own!
titch
West London
SL55 2003
I was in Park with the car running and noticed that it slowly raised it suspension up to maximum height. It then suddenly went back to the lowest setting, and the cycle started again. All four corners are doing the same.
I switched off the car. Waited half hour and tried again. The movement started again. I'm sure it doesn't do it whilst driving.
Anyone experienced this before?
This is an odd one,,, what happens if you press the raise car button
T
titch
West London
SL55 2003
The buttons work as normal. But if already at top height I can lower to normal immediately using the buttons and cycle through all settings. I'm baffled...
Baffling me too as each wheel has its own height sensor
T
titch
West London
SL55 2003
I can post a video if it helps...
pump ? belt ? pulley ?
It cannot be that as this foes not affect the height other than being able to keep up the pressure.
Faulty valve block, then why is it cycling up and down. ECU bad connection like I had maybe.
T
titch
West London
SL55 2003
So if it is a ecu connection, what did you do to rectify it? Give it a good old clean.... Could it be down to water ingress?
Water ingress, thats a good one for this non plausible fault, yes the ABC is in the passenger foot well sill in the Wake up X30/18 connector, and part of CAN C, this is joined to the EIS and instrument cluster, then into the CAN B.
Have you done the mod where you cut the ears off the heater box drain.
I am not even sure if it could be the ECU, mine was a bad connection, but not a fault like this, it may need STAR on this one.
T
titch
West London
SL55 2003
Half that message went right over my head.. Hehehehe.. There are no fault registering so will any show up on star?
That I do not know :( there may not be a warning for this as I have never heard of it on any forum, but STAR can detect faults that are not displayed in the cluster. I am still thinking of the ECU as the raise switch just goes to the ECU. I will need to look at the circuit diagram.
whitenemesis
CLS55 AMG '05
You say it doesnt do this whilst driving? It may be difficult to tell?
Have you checked for water or damp in the passenger footwell and cill channel? The carpet may be dry, you need to lift it and check under the underlay as well
T
titch
West London
SL55 2003
I've only had water ingress problems in the boot so I will check the passenger footwell in the morning.
I may get the missus to drive alongside the car on the a40 in the morning and check if there is a problem whilst on the move too.
If you want to check the passenger side for damp, put the seat right back,you have to remove the side kick panel, its held on with just 1 screw that has a plastic cap on it, the side panel will then lift out once the draft excluder has been pulled back a touch. Get hold of the carpet from the top left hand corner and it will pull back enough enough to feel for any damp.
T
titch
West London
SL55 2003
Nice one. I'll give it a go... Back tomorrow... :)
ajlsl600
france
another one i am watching , to store the answer ! i fly 8,000 miles home and back every 10 weeks , as soon as i hear MB are supplying or making electronic parts for airbus /boeing i am going to start using a boat !!
Boats can sink :(
The parts are nicely made, but sometimes due to where these ECU's are placed leaves a little to be desired. This fault that titch has is rotten, never ever heard of it before.
ajlsl600
france
Boats can sink :(
malc nice point , but . if sinking can swim , not quite so practical from 35,000 ft !!!! this is my 3rd mb, and they are great to drive , but any ford/audi i ever had was more electrically reliable . i still love to drive my 2001 clk320 .which i have mothballed cos its in great shape but worth nothing now . and the w168 is simply a great ,ecconomic runabout , so long as i fix and maintain it myself. however they will probrably all die electronically long before a mechanical or corrosion demise . i cant remember changing bulbs on my fords ,but the merc clk, for example ,everytime i come home there will be at least one driving light bulb that blows as soon as i first put them on ,either side .and each time there is another reduction in pixels or display on the dash . i remember a while ago having a drama with an almost new washing machine , which had a "brain "!!!! where was it fitted .. next to and slightly under the leaking water pump !!!! same mentality seems to apply to benz . almost no watertight r230 boots , where is the pump ,on the boot floor . incidentally my boot right now is watertight the motor is wrapped up in the warm but i WILL make a plan to re do benz ****ty design in this area .same ref damp under passenger side carpet and ecu,s there.. this is a great informative forum . i have almost a bible thick book on info and fixes which i keep in the cars.
www.W140.co.uk&www.r129.co
