- Thread Starter
- Thread starter
- #41
I'm getting back onto this as I have a few days off... I've familiarised myself with the vids on youtube but I've got a question.... With the D2B fibre plugs pulled out, the fibre connector hole from the radio flashes 3 times, suggesting signal is coming from the comand unit. Is it the same for the CD changer and Bose amp fibre holes if the fibre plugs are pulled out? Will they flash to show there is an output or do they only flash if the fibre loop cables are connected??
Am I right or wrong in saying the CD changer and amp should also flash in their fibre holes when the ignition is turned on to show they power up??
I only ask this as I'm trying to determine the faulty part and I'm thinking it's the amp or the CD changer, or both - as when the fibre cable that flashes from the radio is connected to either the CD changer or amp, nothing else in the fibre loop seems the have any light coming through, suggesting theres nothing coming through the amp or CD changer..
