SL55 Ride Height
candellara
Bognor Regis
Hi All
Decided to lower my 2006 SL55 as I felt the ride height was too high
So, I opted for the simple way :) lowering links as the car can be easily returned to standard and it's low cost
The instructions recommend an 8mm adjustment on the links but I opted to do just 5mm as this represents a 28mm chassis drop
Well, suspension is definitely lower but I made the schoolboy error of not measuring the original ride height - dooh!
Can any 55 owner with standard ride height measure group to wheel arch for me - front & rear. Thanks if anyone can help
EDIT: If anyone can measure - can you do it with ABC in sport mode
My car is now (in sport) Front 655mm from floor to wheel arch and rear is 675mm
70cm from arch to floor.
However, the car is always trying to level the body, so if its not on 100% flat ground, you will always get different results. Sports mode makes no difference to the ride height.
C
candellara
Bognor Regis
Thanks. Big help. So, happy with the rear ride height as I only wanted a 1" drop. I'll adjust the front to 675. I assume standard is 700mm all round?
No worries! Same all round.
www.ckinsurance.co.uk
