Slight knocking noise front passenger
ips24
c class c200 cdi 2010
Got a slight knocking noise when on side roads any ideas
My car is a c class c200 cdi 2010 auto
Sent from my SM-G920F using Tapatalk
Could be a balljoint, droplink, sway bar bush, rack end or broken spring.
The only way to find out is to get underneath and check each part
Craiglxviii
Cambs UK
I get knocked from the passenger side too and a lot of whining - it seems to stop when I drive alone ;):D
Sorry, wrong forum...
This was my first thought.
“Issue: whining noise from front passenger area.”
“Solution: remove front passenger.”
I
ips24
Real answers please no jokes.
Adamki83
Mercedes E-class, 2005, E270CDI (2.7) + 1992 Mercedes 500SL (R129)
I don’t know if it’s the same as my E class,
I had a knock noise every time I went over a sharp bump, turned out to be upper ball joints.
This Is how I checked mine on my E-class;
Jack the car up at the front till the wheel is off the ground. Then check as if you testing for a bad wheel bearing rock the wheel backwards and forwards in the 12 and 6 position if it rocks look closely at the upper ball joint if you can see movement it’s the upper ball joint that’s causing the issue!
Yep. On a 211 it can be upper balljoint. On a 210 or 203 its usually (but not always) droplinks. On a 129 its broken swaybar brackets or drag links or steering idler or swaybar bushes or strut top mount, on a 230 its balljoints on the arms or the strut balljoint. We've had knocking caused by broken springs on all cars at one time or another. The only way is to get down and check. Otherwise its only ever a guess.
Yugguy
Rugby, UK
C220CDI W204 Elegance Comand
Suspension top mounts or internal to the shocks.
Adamki83
I swear the suspension is one of mercedes’s Weak points...
David Richardson
Plymouth
W176 Blue Eff CY Sport CDI & C Class Coupe 2002 220CDI
Drop link, seems to be the most common reason for a knock from the front suspension
On the 204 it appears the strut itself or the top mount are the usual culprits. As they are also the most expensive check everything else first by looking at it from under the car and testing each joint.
I
ips24
Done the droplink and the knocking noise still there
Sent from my SM-G950F using Tapatalk
I
ips24
Lost kiwi didnt mean u about the silly answers
No problem :)
If there are no obvious sources of movement in suspension joints then the top strut mount will likely be the culprit or the strut itself.
I
ips24
  • #19
No problem :)
Other than the main dealer where is the next best place to buy parts from
