I get knocked from the passenger side too and a lot of whining - it seems to stop when I drive alone
Sorry, wrong forum...
I gave you the real answer.....Real answers please no jokes.
Sent from my SM-G920F using Tapatalk
Yep. On a 211 it can be upper balljoint. On a 210 or 203 its usually (but not always) droplinks. On a 129 its broken swaybar brackets or drag links or steering idler or swaybar bushes or strut top mount, on a 230 its balljoints on the arms or the strut balljoint. We've had knocking caused by broken springs on all cars at one time or another. The only way is to get down and check. Otherwise its only ever a guess.I don’t know if it’s the same as my E class,
I had a knock noise every time I went over a sharp bump, turned out to be upper ball joints.
This Is how I checked mine on my E-class;
Jack the car up at the front till the wheel is off the ground. Then check as if you testing for a bad wheel bearing rock the wheel backwards and forwards in the 12 and 6 position if it rocks look closely at the upper ball joint if you can see movement it’s the upper ball joint that’s causing the issue!
I swear the suspension is one of mercedes’s Weak points...Yep. On a 211 it can be upper balljoint. On a 210 or 203 its usually (but not always) droplinks. On a 129 its broken swaybar brackets or drag links or steering idler or swaybar bushes or strut top mount, on a 230 its balljoints on the arms or the strut balljoint. We've had knocking caused by broken springs on all cars at one time or another. The only way is to get down and check. Otherwise its only ever a guess.
If you own a Mercedes for long enough, then you'll realise that the wit and sarcasm is the only thing that keeps you going.Real answers please no jokes.
Developing strength of character helps you hold back the tearsIf you own a Mercedes for long enough, then you'll realise that the wit and sarcasm is the only thing that keeps you going.
Absolutely.Developing strength of character helps you hold back the tears
On the 204 it appears the strut itself or the top mount are the usual culprits. As they are also the most expensive check everything else first by looking at it from under the car and testing each joint.Drop link, seems to be the most common reason for a knock from the front suspension
No problemLost kiwi didnt mean u about the silly answers
Sent from my SM-G950F using Tapatalk
Other than the main dealer where is the next best place to buy parts fromNo problem
If there are no obvious sources of movement in suspension joints then the top strut mount will likely be the culprit or the strut itself.
