Probably same set up as my Clk , which has adjustable front wheel bearings , so I would guess under an hours work for a garage . Provided they are not too wornC class 2012 coupe
Had MOT done today. Have slight play on both from wheel bearings.
Is the cheap to rectify? Do Mercedes look at this and repair when servicing?
Luke
See what I said on your other thread ...it's extraThe guy said there wasn't much in it.
Do you know if mercedes tighten them as part of a service or is that generally extra?
Been told it's not the same setup. They can't be "tightened" need replacingProbably same set up as my Clk , which has adjustable front wheel bearings , so I would guess under an hours work for a garage . Provided they are not too worn
They can be tightened...and don't leave it until your next service. You can do it yourself...it's easy. You tube is your friend.
Is it a home mechanic job? I had always understood the tolerances to be fine so you'd need a gauge of some sort to ensure you don't overtighten.
