Slight play on front tyres
Luke88
Anglesey
Mercedes c180 coupe 2012
C class 2012 coupe
Had MOT done today. Have slight play on both from wheel bearings.
Is the cheap to rectify? Do Mercedes look at this and repair when servicing?
Luke
C class 2012 coupe
Luke
Probably same set up as my Clk , which has adjustable front wheel bearings , so I would guess under an hours work for a garage . Provided they are not too worn
L
Luke88
Anglesey
The guy said there wasn't much in it.
Do you know if mercedes tighten them as part of a service or is that generally extra?
See what I said on your other thread :) ...it's extra
L
Luke88
Anglesey
Cheers
L
Luke88
Anglesey
Been told it's not the same setup. They can't be "tightened" need replacing
Avnt
Mexborough
Mercedes c350 cdi estate amg
Surely its the same as any 204 chassis car?
L
Luke88
Anglesey
Was told by an independent mechanic that they need to be changed and can't be tightened
om613
london
S202 C250TD, S123 240TD
Change him...
Naraic
2005 CL500.
They can be tightened...and don't leave it until your next service. You can do it yourself...it's easy. You tube is your friend.
mercedes13156
West Lothian
CLK 200 Cabrio and a Ford Kuga
Piece of cake. It won't take you long. Ignore the advice from your mechanic because he is telling you lies and he is looking to take you for a ride.
Yugguy
Rugby, UK
C220CDI W204 Elegance Comand
Is it a home mechanic job? I had always understood the tolerances to be fine so you'd need a gauge of some sort to ensure you don't overtighten.
L
Luke88
Anglesey
It was just a mechanic on a FB who advised me. Not looking for work.
Different manufacturers do it different ways. Some you torque up to **ftlbs & then back off to the next castleation. Other makers just have a bearing that is part of the hub & there's no adjustment, you just tighten to FTftlbs
Frontstep
T210 320cdi
Repack with grease and reset comfortable 1/2 hour for garage.
1 hour includes tea, biscuit and discussion of world affairs.
umblecumbuz
Wales and Gozo
The front wheel bearings are taper roller, and Mercedes have a simple and accurate adjusting setup for them.
Once the wheel is off and the centre protective cap is removed (screwdriver pops this off) you will see a clamp which is locked in place with a hex-headed setscrew. Loosen this with an allen key and the clamp will be free to turn. Rotate until you feel the bearing begin to tighten up (slight increase in turning resistance), then back the clamp off a fraction, and you have it. Repack with grease and tighten the setscrew, refit the protective cap.
Both front wheels can be done in less than half an hour total.
Hope that's a help.
Umble
om613
london
It was just someone online. Why ignore the advice?
Because it's incorrect.
As the subsequent posts say, a really quick, easy job to lube and adjust them.
Yugguy
Rugby, UK
Might have a go at that then as I have a slight play on mine.
Will lith-moly grease do, do I need a gun to get it in?
www.ckinsurance.co.uk
