SLK 320 suspension "vagueness".??
nine468
Hi Folks.
We have a 170 series SLK320. [Rare Manual].
Recently it seems to have developed a strange vagueness in the rear suspension.
When driving over uneaven roads / small potholes, the rear end seems to want to "rear steer".
There is also a "loose" feeling when selecting reverse / forward gears from stationary. As if the rear subframe is moving up + down..
I have had a look underneath, with the use of a 2 post ramp. It seems like the two main bushes, no,s 100 on the attatched pic.
have worn causing the "loose" feeling.
http://www.detali.ru/cat/oem_mb2.as...660716.667&CT=F&cat=66E&SID=35&SGR=045&SGN=03
How easy is it to replace these bushes, as it seems they are two of the 4 main bushes holding the rear subframe in place...???
Anyone done this job..
For those that are used to using the site where i got the attatchment from,,,Could you please tell me... On the picture, there are small spanner symbols. What significance do they have. Are they a "how to " guide.?? If so, how do i access it....
Hi Dave, I can send you a how too, there is not much to it and the bushes are pressed out
There are no "how to's" on the ruskie site.
We have another on goping thread with a 202 and the same thing.
PM me your Email address
Its only a simple clamp to push it out with, or cut the old one up with a hack saw or sharp chisel
