Sprinter CDI 316 March 2015 (MY2013) Reversing Camera
AirCon
London
Sprinter MY2013
I've purchased a reversing camera from a German Ebayer (claimed OEM).
It comes with German only instructions hence my questions on here.
The Radio (Command Module) is an Alpine RY2350 with the video input on a turquoise connector (the only one not used).
I've connected switched 12V power via the glove box and the video.
Then switched on the ignition (so the camera is now powered).
Waiting 30 seconds and connected this "programmer" to the OBD port as described, however the LED light on the programmer just comes on and stays on forever (well 20 minutes is all I gave it).
The instructions say the lamp will go out after 1 minute and Diagnose will come on the command units display. But they don't.
Anyone had any luck retro fitting these cameras?
Note the camera is working if I use an alternative monitor.
It appears that the "programmer" (Hinweise Diagnose Interface Mercedes) is not working correctly or I'm doing it wrong.
I await your collective wisdom
A
AirCon
London
Sprinter MY2013
  • #2
Please help
Anyone?:-?
ELGRINGO
fylde coast
e230 c180 sl280 brabus a190 smar cart
We work on a fleet of sprinters but never fitted a reverse camera, i would of thought that you should code the front sam.
I do not know this one at all, but when I add anything to the mercedes Comand I have to put it on STAR to program it in.
ELGRINGO
fylde coast
As malcolm says suspect needs coding, could not believe went to local bodyshop to code in new head lights after front end smash. they would not work when just fitted, need coding its going stupid.
