"Steamy Windows" SL R230... and we 'aint talking Tina Turner!
N
Nile Griffith
Worcestershire
2009 Sl350 R230
  • #22
I did hear a rumour that when they sold the old SL65AMG pace car from the Bahrain GP track, that the only fault they found with the car was moss growing in the boot.
rexemper
Berkshire
R230 SL500 - oh yeah!
There was a R230 on here fairly recently that was leaking in from the rear quarter windows and causing damp.
If you’re not finding damp anywhere I’d stick a dehumidifier in and let that suck it completely dry and then see if the condensation comes back.
Any idea where that thread is? I'd like to see how it was fixed/resolved. Am currently running the dehumidifier in the car and may have a similar problem.
OP - did you get to the bottom of it in the end?
This thread might help
rexemper
Berkshire
Thanks. I just read that thread and his issue seemed to be his quarter windows being stuck. Mine are still working.
Or did you refer me to that one due to the possibility of the drains below the windows being clogged up?
Also, if those drains are clogged up, other than the window getting stuck what are the other potential symptoms? Asking as my rear carpets on the SL are wet and I’m trying to work out how they’re getting that way.
RhodieBill
A lot of it lately has to do with the very deep lows we have been experiencing lately. That coupled with sudden drops in temperature aid condensation sticking to windows etc.
It can be worse if in the mornings your car is in the sun, the interior temperature inside the car builds but the exterior remains the same. You get the same effect as a cold glass of Beer, it gets wet on the outside because of the differing temperatures. Cold inside, warm outside. Well your windscreen is like the glass but in reverse. Also everytime you get in and out of the car in the rain you transfer moisture into the car, sticks to your seats, floor etc. This evaporates when the temperature inside the car rises and condenses on the cold windows.... Simple physics.
There is moisture in the air all the time, especially at this time of year - don't you notice the roads stay wet even if it hasn't been raining..??
I would only worry when there is water streaming down all your windows and forming puddles. Then you have a problem!
On sunny mornings and if your car is in the sun, open your windows about 2cm. That will let the hot air out - no condensation.... Simples. :cool:
Because of the drains being blocked on the quarter windows
Thanks. Is it windows out to get those unclogged or can you get to them some other way?
That I don’t know as I’ve only driven R230’s not spannered on them. I just know they leak (a lot) :( but are nice to drive when not leaking
6500RPM
SL350
Drains for rear windows, not sure if this will help or not.
rexemper
Berkshire
Thanks. He seems to have the windows out already. Don’t fancy trying to take them out myself!
Would be great if there was a way to clear the drains some other way.
6500RPM
SL350
I have not investigated these drains yet, but if they drain into the rear arches, could you not clear them going backwards?
rexemper
Berkshire
Thanks. Worth a try once I get the inside dry.
From the video they seem to drain out of the same place in the arches as the drains under the pointy ends of the boot lid.
00slk
Cambridgeshire UK
I am sure those two holes are the extension of the holes in the rubber seal you can see when the top is down. On mine I blew these through with compressed air. Might be worth me doing these again me thinks :rolleyes:
ajlsl600
france
Why does the gf hate aircon ? Very little extra fuel is used these days with it on , it dries the air and keeps moisture out the car .
Try and sell it to her that the new frecious filters combined with aircon filter out soot and other nasty micro particles that would otherwise end up in her lungs :D (it’s not true but might let you run the aircon )
Failing that get a new one in the New Year :rolleyes:
Leave a pushbike by back door next time u go out.wid aircon on .simples.
rexemper
Berkshire
I've got it booked in later in the week to get it looked at (along with another job) so will report back when they've had a look.
Washed it earlier today and didn't see any leaks where I had seen them before - on the small ledges by the rear quarter windows.
It could well be the drains below the side windows, just not sure how to get to them without taking the windows off.
00slk
Cambridgeshire UK
Hope they can sort it, you'll keep us up date though wont you ;) :)
Tju
Essex
S211 OM642, A209 320, W220 OM648
If you have determined it is not damp related, wash the inside of the windows with warm soapy water, to remove the film that builds up on the inside of the glass from the constant use of Air Con, this works for me!
