tailgate adjustment w203 estate
Discussion in 'Bodywork, Tyres, Wheels & Trim' started by dubburke, May 11, 2018.
  1. dubburke
    dubburke Active Member
    40
    Dec 20, 2014
    N.ireland
    Your Mercedes:
    mercedes c220 cdi
    I know the kick plate needs to be removed to access the torque screws for adjustment, but I cannot remove the kick plate, I have removed the screws, but it will not budge, and I don't want to force and brake something.
    Is anything else holding it in place?
  2. umblecumbuz
    umblecumbuz Senior Member
    3,071
    495
    Sep 20, 2010
    Wales and Gozo
    Your Mercedes:
    S204 and CLC 204 cdi, other non-Merc machines
    I had to do this with mine - a 2004 model, now sold.
    The stainless kick plate along the lower edge of the opening is clipped on. It takes some 'springing' off and also needs a feel for the metal as you do it.
    Once I'd adjusted the striker so that the tailgate closed better, I also needed to adjust the two rubber bump stops, each side of the opening.
    Hope that helps.
  3. OP
    dubburke
    40
    Dec 20, 2014
    N.ireland
    Your Mercedes:
    mercedes c220 cdi
    How are the rubber bump stops adjusted? Maybe I will see how when the kick plate is removed?
  4. umblecumbuz
    3,071
    495
    Sep 20, 2010
    Wales and Gozo
    Your Mercedes:
    The bump stops (doubt if that's the correct name, but ...) are part way up each tailgate pillar on the bodywork. I think I had to loosen them and move them, but memory fails me. It should be easy to sort out though.
  5. KeithJG
    KeithJG Senior Member
    140
    14
    Dec 31, 2014
    Dover, Kent
    Your Mercedes:
    C320CDI Sport Edition S203 2006 V6 7g
    Don`t think my S203 is the odd one out but they do not have any adjustment on the tailgate half way up?
    Nothing on the tailgate and just a moulded piece of metal on the body......nothing to adjust only at the striker.
  6. OP
    dubburke
    40
    Dec 20, 2014
    N.ireland
    Your Mercedes:
    mercedes c220 cdi
    I think you are right, I cannot see anything to adjust on the tailgate or body.
  7. umblecumbuz
    3,071
    495
    Sep 20, 2010
    Wales and Gozo
    Your Mercedes:
    My apologies gents - there are no 'bump stops' on the S203.
    I was thinking of another car.
    My 203 is sold long since and my memory is even rustier than the early 203's!
Share This Page
