tailgate adjustment w203 estate
dubburke
N.ireland
mercedes c270 cdi
I know the kick plate needs to be removed to access the torque screws for adjustment, but I cannot remove the kick plate, I have removed the screws, but it will not budge, and I don't want to force and brake something.
Is anything else holding it in place?
umblecumbuz
Wales and Gozo
I had to do this with mine - a 2004 model, now sold.
The stainless kick plate along the lower edge of the opening is clipped on. It takes some 'springing' off and also needs a feel for the metal as you do it.
Once I'd adjusted the striker so that the tailgate closed better, I also needed to adjust the two rubber bump stops, each side of the opening.
Hope that helps.
D
dubburke
N.ireland
mercedes c270 cdi
How are the rubber bump stops adjusted? Maybe I will see how when the kick plate is removed?
umblecumbuz
Wales and Gozo
The bump stops (doubt if that's the correct name, but ...) are part way up each tailgate pillar on the bodywork. I think I had to loosen them and move them, but memory fails me. It should be easy to sort out though.
KeithJG
Dover, Kent
C320CDI Sport Edition S203 2006 V6 7g
Don`t think my S203 is the odd one out but they do not have any adjustment on the tailgate half way up?
Nothing on the tailgate and just a moulded piece of metal on the body......nothing to adjust only at the striker.
D
dubburke
N.ireland
mercedes c270 cdi
I think you are right, I cannot see anything to adjust on the tailgate or body.
umblecumbuz
Wales and Gozo
My apologies gents - there are no 'bump stops' on the S203.
I was thinking of another car.
My 203 is sold long since and my memory is even rustier than the early 203's!
