Urgent help needed please
markm730
Oldham, Mcr, UK
Mercedes C230 kompressor 1.8 2004
Please advise if possible
Just replaced the car battery, connected back up and attempted to start. Not even accepting the key fob. Is there a sequence I have to do in order for it to be accepted or is there something I've missed.
Cheers
Mark
It should just work. I changed my E Class battery last week and it just fired straight up. You have connected it the correct way and all the terminals are tight? The battery is charged?
markm730
markm730
Oldham, Mcr, UK
Currently assuming it's fully charged as its a new battery. Yes connections on tight and the correct way round. I've done nothing different, it's just not accepting the key.
Does the interior light come on when the door is opened?
ajlsl600
france
try disconnecting ,check full charge and connecting again, bizzare ..
shine
Hampshire
CL 500.W216 + C300 Coupe AMG Line 2018
Have you another car you can try a battery that has a charge in it.?
malcolm E53 AMG
Probably a dud as above see if the interior light comes on or put a meter across the battery. Do you still have the old one reconnect that if so to check
Just because the battery is new , you don't know how long it's been on the shelf before you bourght it . It should have a date of manufacture stamp on one of the terminals . I'd go with it needs charging first
markm730
markm730
Oldham, Mcr, UK
Thanks chaps
Managed to get it started with jump leads, key now accepted ,left it running for a while and a run home, turned it off and back on again. No joy.
Going with the concept of it being a dud!
Will be straight back to the place in the morning as I've been trying to sort it for most of the day, not best pleased.
Thanks again for your replies
sonic
Staffordshire
E350CDI, SLC250d, FJR 1300
No uncommon to have a dud new battery, I have had one but many years ago.
V6Matty
Newark, Nottinghamshire
Dud new batteries are quite normal, had one just a couple of years ago on the wife's car
Botus
S500/2010/500
mb grangemouth, for the genuine bit, half price of the crooks selling other stuff
delivered for a fiver, by wednesday
