OmniCognateNeutronRangler
- Thread Starter
- Thread starter
- #41
Lets all have the right terminology
It is silicone not silicon that they put in the fuel, silicones are liquid materils used as lubricants and the like they decompose when cooked into silicates, on the other hand silicon is glass like and solid used to make transistors and as an ingredient in special steels etc.
It was silicone that some poor folks got foisted off with instead of petrol and will decompose into some sort of ash coating on the hot gas side of the lambda probe oxygen sensors reducing their efficacy as a sensor to a degree dependent on the contamination, this may burn off the sensor in time but may not do at all. The sensor is a tube of I belive zircon which is exposed to hot exhaust gas at one side and atmosphere at the other. when running hot (@ 200-300 degrees C) it develops an electrical signal the magnitude and polarity of which can be used as a reliable measure of exhast gas composition, the signal tells your ECU to inject more or less fuel to correct the air/fuel ratio to that required by the 3 way catalytic convertor if it is to be effective in controling emmisions.
The sensor is fitted in the exhaust pipe after the engine and before the cat convertor
I am left wondering as to what if any other damage has been done to both engines and cats by the ash deposits that must have resulted in parts of cars which have been affected by this rather nasty manufacturing error.
If the damaged sensor has led to the ECU adding extra fuel oil washing will have occured in the cylinder bores promoting extra wear of the piston rings and bores, if the cat has got some ash on top of its precious metal (platinum) coatings its life will be shortened.
Does Tescos admission of fault and willingness to pay for repairs also extend to potential long term damage?
its a damned good question. let me put it this way; I don't intend keeping the car long enough to find out. The trouble is, of course, anyone that buys a 2nd hand car now may be buying one that has been affected and may develop faults in the future as a consequence. I guess the answer is to only by cars from "ooop norf"
