- Apr 18, 2006
- Location
- Taunton
- 220d (115), 190d (201), c63 (204), 220ce (124)
If the main instrument cluster back lighting is working, but none of your console lights illuminate (eg window switches, heater control switches etc) then you need to pull out the dash cluster, and on the back of it behind the oil/temp/fuel gauge (pictured) you need to replace that little red diode which is circled, then your lights will work again.
