W124 Centre console lights not working - solution.
robparker
Taunton
If the main instrument cluster back lighting is working, but none of your console lights illuminate (eg window switches, heater control switches etc) then you need to pull out the dash cluster, and on the back of it behind the oil/temp/fuel gauge (pictured) you need to replace that little red diode which is circled, then your lights will work again.
donpmg
W124 200D/ 1988/ OM601
is there a part number for this part?
DREAMER NO2
W124 2.6E M103 1989
Rob only thing is they are so hard to find for the W124 model . [ keep well mate ] Trev
donpmg
No issues with continuity of the red diode/fuse. Still the center console lights (window switches/ power mirror switch & fader) do not light up. All other lights are okay. Anything else to look at?
Would be helpful if there is a schematic of how the lighting is connected for the these switches.
DREAMER NO2
W124 2.6E M103 1989
donpmg
I have checked the continuity and there seems to be no abnormality within the cluster pcb. Any diagram on how the wiring and supply works through the cluster to the center console switch illumination?
DREAMER NO2
W124 2.6E M103 1989
What you think is a fuse, is a diode,, Rob in the first post told you that ,,i think you need to find a new one If you lucky Rob might have one ..
donpmg
So even if there is continuity to the instrument cluster illumination lights within the cluster through the red diode, can this being defective cause the center console lights (window switches/ speaker fader switch / power mirror switch) to not work?
The main dash lights are also working with no issues.
DREAMER NO2
W124 2.6E M103 1989
Message Rob on post one ...Rob works on thousands of Mercedes and he will know ..Robs seen inside of theses mercs that no one else as .
DREAMER NO2
W124 2.6E M103 1989
No i know that now , but poster donpmg must have searched Google and this came up from Rob , so he tagged on to it not knowing it was 2014. And i only came in on to post 2# so i did not know it was going back to 2014 ..
donpmg
Yes noticed that but did send a message to Rob hoping for an advice.
Any other experts have an insight on this?
