W163 ML270CDI - OIL LEAK, ANY SUGGESTIONS RE DIAGNOSIS?
mooreic
London
S430/1999/4.3
Afternoon All. I wondered if anyone had any suggestions on what might be the cause of a slight oil leak under the engine bay of a 2002 ML that I bought very recently.
Having benefited in the past from the combined wisdom here, I'd like to check what people think it could be before I go back to the dealer. I'm obviously hoping that it won't be anything major required like manifold replacement.
When I bought it, I asked for the dealer to do an oil change (& oil filter), which he did. When I viewed it beforehand, I got the dealer to take off the engine cover and there was no sign of the dreaded "black death". There was also no obvious oil leak (or any advisories) listed in the recent MOT and nothing appeared to be under the car at the dealers after I'd test driven it.
The car has driven well since I've had it and was a pleasure to drive from the Midlands to London (2.5 hours on A roads and the M40) with no obvious "steam train" engine noises or similar. I'm hoping that the oil is simply excess oil that got spilt or left in the engine bay during the oil change - is that realistic?
I've tried to attach a pic to show how much the "leak" is - this was after 24 hours of being parked up with the car moved a few metres to show the oil IMG_4970.JPG . There were similar amounts for the previous 24 hour periods.
Any suggestions for how I might diagnose what the problem might be would be much appreciated!
Thanks very much in advance.
Steve@Avantgarde
Bristol/Somerset
Is it oil? Could it be transmission fluid? Possibly diesel? What colour is it? Which way was your car parked when it left that deposit?
Hard to tell from that picture really.
Are you sure it's from your car ?
Look around your engine with a torch and underneath to look for drips .
M
mooreic
London
S430/1999/4.3
Thanks for the quick replies. Definitely from my car as nothing there before & I reversed my car to take the pic.
Car was parked driver's side to kerb so one of the patches (smaller) was near the front left of the car & the other larger one under the engine more in the middle. Small patch is size of mug and the larger size of small plate.
When I checked it it seemed like oil (colour light brown - transmission fluid is pinky red isn't it?)-it was refilled with I think 5w30 fully synthetic.
Because of the plastic under trays , the oil may move along them before it finds a hole to drip out of , so the floor position won't really point to a location .
M
mooreic
London
S430/1999/4.3
Good point! I will keep monitoring and take to a local indie if required. Thanks.
