W169 Armrest - what were they smoking?
ZZZZ
The W169 armrest is not a pinnacle of Mercedes engineering, I am sorry to say: almost zero functionality, particularly for a RHD car (as Mercedes didn't bother to reverse the layout); doesn't open, so no useable storage underneath; moves forward 2½" to reveal a tiny 1" x 3" cub, and in doing so displays an appalling design flaw:
The plastic groove / metal pin tolerances are huge, and there's a noticeable play - very annoying.
Unfortunately, fixing it in 'forward' position is not an option, as it has to move back, to allow access to the parking brake (for adjustment, etc, not for normal operation, so was tempted...)
I have just removed the top to have it leather trimmed, and was wondering if anyone can suggest what can be done to rectify this problem.
David Richardson
Plymouth
W176 Blue Eff CY Sport CDI & C Class Coupe 2002 220CDI
If only there were a useable aftermarket model that could actually be used mate.
Z
ZZZZ
I'm now seriously considering fixing it in forward position, after having the top leather-trimmed, as I can't see how the play can be reliably remedied ...
area51
Kent
Year2000 A160
Would it be possible to sleeve the metal pin with some heat shrink tubing?
This might take out some of the free play but would entail some work.
Z
ZZZZ
Thanks Chris, that's very interesting, just not sure how long will the heat shrink last, with constant friction?
I thought of finding a suitable PE tubing for the pin, but heat shrink is obviously a much better solution.
That, or fixing a metal strip to either the top or the bottom slide ...
The other problem is - taking the rocking/sliding part off of the top cover will require breaking it off essentially - a few rivets holding it together ... Honestly, I'm very tempted to just nail it shut, so to speak!
Fit a thin wall metal tube over the pin? Or wrap it in shim brass?
area51
Kent
Year2000 A160
Heat shrink is quite tough stuff once it's been shrunk.
How about lining the groove with self adhesive felt strip? MB sell this in a variety of widths (it's on EPC), I've used a lot of this on my 168 sorting interior trim noises, binding wiring and so on.
The rivets, are they metal? Drill them off and fit new ones?
Z
ZZZZ
Ah, something else I didn't think about. I love this forum! Cheers Alastair.
As I am hoping to comeback to life, if there is anything or help please ask David, you do know me
Thanks Malcolm, I'll definitely pop in for a chat and advice later on. Also wanted to show you the new bonnet badge and ask about steering buttons assembly removal ...
That's good to know - maybe that's all I need.
Great, I actually have some that I used to repair a medium format [film that is] camera - Mamiya 645 - a couple of years ago ...
The rivets are plastic, some heat-welded, and there are a couple of metal rods that I can probably just hammer out.
Being a very lazy erm ... individual, I was trying to find a solution that didn't require taking this apart.
Yes, it is shameful :(
Z
ZZZZ
Just to be on the safe side, what's the part number(s) or category to look for this. I think I'll need a 3mm one
I keep heat shrink in most sizes, what ever you want is take you like, never get stuck ever with electrics, I have the strength now I hope that is hear to stay. If it rains you can use the garage
area51
Kent
Year2000 A160
On the left hand top corner of EPC home page; MD Mode- Paint/operating fluids- Car- 19 Sealing tapes/cords.
Z
ZZZZ
Fantastic! Thanks Malcolm :)
Blimey I have Mamiya 645 upstairs :)
What?! It's mine! ;)
I actually put that kit together for our friend's daughter - she was taking photography at Northampton College - it was surprisingly inexpensive to acquire a body and three lenses ... best birthday present ever she said.
Brought back some memories too - I had a full set of Press 23 Pro (as in every lens, adapter, back (even 70mm) and accessory LOL); RZ67 and a 645 back in 80s-90s o_O
Not yours - this one came from NZ!
I did have a 645AFD-II for a while too. That was a lovely thing and I regret selling it as I could have converted it (for a medium sized mortgage) to digital.
The ordinary 645 is very cheap for lenses etc and a decent film camera.
I also had a 330 Pro TLR. Loved that. Sold because I wasn't using it but may well get another at some point.
I'll post an image taken on the 330 in the photography thread sometime.
Z
ZZZZ
  • #17
Just to update - following the armrest re-trim by Jack at the Royal Steering Wheels, to match the gearshift handle, and the steering wheel, he did earlier, I managed to rectify the problem, without having to completely disassemble the base of the armrest: a combination of a felt strip, gentle adjustment of plastic rails (heated), and some lithium grease solved the issue.
Many thanks for all the suggestions, much appreciated :)
