W210 OM613 Water Pump
bob 6600
Audi S8 V10, S210 E320 CDI (R.I.P.)
Should this have these 'cracks'? The pump is not very old and I'm not sure if it's manufactured like that or if it's cracked (in 3 places)?
Pullman
ESSEX
1981 500SL_1999 500SL_(2002 CL600 sold) 2003 500SL
not familiar with this model but this dont look like casting marks and I would presume the casting should be one piece ... was it leaking? ...I would change it regardless ... all the best
dave
Sent from my Nexus 5 using Tapatalk
bob 6600
bob 6600
Thanks Dave
I have a leak I cannot find! Checked everything 6 times and I think this is causing it. It seems it's causing a very small leak which runs under the car, down the sump. Problem is, I had a very small oil leak there two, so couldn't really tell if it was oil dripping or a mixture. I will replace with new, although the only reasonably priced ones are from ECP/CP4Less which are the same brand as this one. Genuine MB is around 4 times the price.
Anyone know of any decent manufacturers of water pumps?
bob 6600
bob 6600
OK I've just checked online and found this picture. Two of the three 'cracks' are there
Pullman
ESSEX
Bob ...did think the two straight marks looked man made .... from your description of the water leak I would still change it tho' ..
bob 6600
bob 6600
Small update as I don't like to leave threads unfinished.
Water pump changed for a Febi unit. It also has casting marks but only two on one side which seems correct.
Early days but no leaks, let's see how it gets on. Fingers crossed
