W210 Resistor side light:
aaz1978
E430 W210
Hi guys i have lamp defective warning on my car, and it is because one of the side lights is receiving about half the voltage and is not as bright as the other one. I have figured out that is a resistor problem. I buzzed out each of my lights and figure out what pins need to be used. On the light that is receiving half the voltage it did not buzz. The one that works seems to give me a reading of approximately 2.5Ohms (could be higher), what kind of resistor do I need, i.e. power rating and type? I assume it will need to be fairly high wattage.
Something like this perhaps?
http://www.maplin.co.uk/7-watt-wirewound-resistor-2179
Cheers
You have a poor ground lead some where near the lamps, there are no resistor in the fronts and there was a modified harness for the rear lamps where the bulbs kept blowing, 1 ohm from memory
A
aaz1978
E430 W210
There is a resistor for the front one, I could see it. I even used my multimeter to measure it, the good one of course. Its probably a current limiting resistor.
Something new for me then, I will take a look later
I cannot see any resistor in the diagrams :(
A
aaz1978
E430 W210
Interesting, I will take a picture and show you what I see. Cheers for looking.
A
aaz1978
E430 W210
Thanks for the diagram will have a look at it, see attached , a picture is worth a thousand words, I am starting to think its a fuse.
A
aaz1978
E430 W210
Erm can't attach the file its over 200kB
Only via a host site or make it smaller
A
aaz1978
E430 W210
Ok got it round it by taking a screen shot and saving as jpg, don't understand why pdfs have a small limit, anyways here it is.
Well that certainly is a wire wound resistor, but I feel it has been added at some point
stuboy
W210/2001/3.2 Petrol
W210 2001 my resistor has just blown in my Left hand side light, its a 2.5ohm resistor of about 1watt rating.
Why do they need to limit the current to the side lights in this way?
Mine may have gone as i put in LED bulbs (CAN bus enabled ones) I cant decide if to straight wire or replace the Resistor. Anyone know for certain from Merc what it is there for?
Regards
Stuart
www.W140.co.uk&www.r129.co
