w211 220cdi judder(taxi)
SHAMGIT
york
w211 2008 220cdi
w211 220cdi estate 58 reg,198000 miles,all wheels are balanced,gearbox mount changed 40,000 miles ago, still original centre prop bearing,original doughnut ,the engine mounts have not been changed there is no vibration from the engine on tick over and the mounts are not leaking,
new atf and filters 15,000 miles ago,
problem started with minor vibration which wheel balance didnt cure, when vehicle is cold no judder,when hot vibration gets worse,68mph to 73mph quite bad,take foot of accelerator and it disappears,on a hill under power at 30mph judder is quite bad possibly in 3rd gear,
ok guys is it going to be lock up valve ,torque converter,or some other nightmare ,any suggestions appreciated,.........thanks in antisipation
Unlikely to be gearbox. Rubber donuts or prop bearing would be my pick.
SHAMGIT
york
w211 2008 220cdi
update on judder,got very bad,
did homework on this site and all over the web,
followed lost kiwi advice,
donut ok ,
replaced gearbox mount,
centre bearing with housing was replaced,
rubber ring in housing was well shot,
drive improved slightly,
decided to read up on dr trannies shudder fix,
the more i read it the more it pointed me to the lock up valve,
decided to invest in 4 tubes for £24...e bay...
got car to operating temp,
put in 2 tubes,
drove for 15 mins,
following day drove for 25 miles,
felt a slight improvement,
that night as a cabby drove about 75 miles constantly up and down the box as most was town work,
at 3 am got out on the bypass and ran it up to about 80 mph,
absolutely amazing,
shudder virtually gone,
over the next week got better still,
stuck the other 2 tubes in.
have now done a couple of thousand miles,
very happy cabby chappy,
so if it was the lock up valve it must have cleaned a jet out,
hope this is of help to someone......
