W211 om646 crank no start
Steve@Avantgarde
Bristol/Somerset
So you have delivery pressure.
Have you measured the pressure at the fuel rail after the HPP (you can usually do this with live data from a scanner)
C
Clas
W211 e220cdi 2007
  • #22
I got about 55 bar
Steve@Avantgarde
Bristol/Somerset
I got about 55 bar
Id say either the HPP is goosed (did you fit a new one?) or there is an instalation error with it. If your delivery pressure is correct, your HPP should covert it to high pressure almost instantly.
C
Clas
W211 e220cdi 2007
  • #24
Ive tried 4 different high pressure fuel pumps now
C
Clas
W211 e220cdi 2007
  • #25
Could it be that it is too much pressure from the pre pump
C
Clas
W211 e220cdi 2007
  • #27
Where are you getting the pumps from and are you fitting the correct one?
I bought a spare parts car and I tried that one, than I tried one from my dads car with the sand motor and it diddnt Work then I bought one from eBay and still nothing
ajlsl600
france
Wud seem unlikely that all ur pumps are faulty. It's difficult to see how u cud screw up the pump install on common rail. It wud seem ur press feed to hpp is suspect or the fuel is rtning to tank, or never arriving at hpp in enough volume for it to convert fuel to req h press.
C
Clas
W211 e220cdi 2007
  • #29
Ive got fault code 221b
ajlsl600
france
Low, fuel pressure. But you already know that. If ur pump starts the car it was in. You likely have an unplanned fuel rtn to tank, or an obstruction
C
Clas
W211 e220cdi 2007
  • #31
Now I have 20e7
