W212:E350 2010 model, odd noise/vibration at certain speeds
anyweb
Sweden
www.niallbrady.com
c238,w120 (diesel)
hi,
lately i've noticed an odd noise coming from my car (not sure if it's from the engine, drivetrain, or exhaust, it's hard to pinpoint), when accelerating but never when hard accelerating, so it only occurs some times, and for a few seconds and then it's gone,
for example, if i'm on the motorway and I accelerate from say 85km/h to 110, between 90 and 95km/h the noise will come, the noise sounds almost similar to that noise/vibration you hear when you drive over cobblestones, but not quite as loud, it seems to occur mostly in two places, i.e. approx somewhere between 40>70 km/h and 90>110 km/h
any body else had a similar issue or know what might be causing this ? i'm still paying off last years Turbo failure so i'm really hoping this is not another expensive problem manifesting itself...
thanks in advance for any good advice
cheers
niall
JohnnySBC
London
www.ecu-repair.co.uk
W212 E350 - Remapped --->>> 300 bhp
Hi... strange problem you have, maybe something from the tyres ? i myself have a noise but i know certainly is from drive shaft rubber bearing ...
bembo449
gainsborough , lincolnshire
reads like possible CV joint issue , had it on a few cars before but its going to be hard to pin point pal , like most noises of this ilk
anyweb
anyweb
Sweden
www.niallbrady.com
c238,w120 (diesel)
i've changed wheels and tires and the problem persists so i'm very confident it's nothing to do with them
star
Reading
Smart + others :)
Torque converter judder??
anyweb
anyweb
Sweden
www.niallbrady.com
c238,w120 (diesel)
if it is the Torque converter juddering, how would I prove it ?
star
Reading
Smart + others :)
Knowledge, feel and on certain tcu's you can switch it of temporarily to test.
Steve@Avantgarde
Bristol/Somerset
Doing loads of engine mounts and subframe bushes on the 212s at the moment for vibrations..
Without looking at it/driving it, it is impossible to tell you.
Arudge
Cradley Heath
CLK200 2000 Kompressor
Could be engine mounts. When they collapse an internal bolt starts knocking on another internal component. I'm told engine mounts have a service life of 100,000 miles.
To test. With the bonnet up, foot firmly on the brake, rev the engine to 2000 rpm in drive. Watch to see if the engine lifts, some movement is acceptable but not much.
See if you can post a video of it.
anyweb
anyweb
Sweden
www.niallbrady.com
c238,w120 (diesel)
thanks for all the ideas and advice folks, i'll try that test with the engine on the weekend when it's light
anyweb
anyweb
Sweden
www.niallbrady.com
c238,w120 (diesel)
also my car has done 238,000 kilometers which is approx 147886 miles so i guess it could be them...
