W216 CL500 Groaning noise LH side
Will Barber
Cheshire
2012 CL500 (4.7L M278)
Hi all.
On route to an event this morning I "opened the taps" on my 2011 CL500 and immediately started to hear a whining noise. At first I thought it was the turbos but then thought it's never done that before so why should they now?
It was only briefly that I held it at full chat (10 seconds or so) and after coming off the throttle the noise disappeared after a few seconds. However on the way home, again after giving it some work to do, the noise returned but got much louder and seemed to turn into a groaning noise, coming and going for the next 30 miles or so.
Performance isn't effected, and it seems to be coming from the mid LH underside of the car.
My first thoughts are could it be the fuel pump (if it is indded underfloor mounted), or is the pump in the fuel tank on this 2012 model year car?
The car has done 67k miles and has full dealer service history.
There are no logged faults either.
Any guidance would be much appreciated.
Thanks, Will
John Laidlaw
Wirral
Land Rover Discovery 4
Interesting
I think the fuel pump is under the back seats but not 100% sure on your model (plenty CL owners on here can pipe up hopefully)
I had a similar groaning on my SL which presaged my ABC pump failure
I’d get it on Star quickly to diagnose accurately- have you got an Indy you use? Plenty our way
Check your ABC fluid level. If it's low it may be related and an ABC sphere may have failed. The pulsation damper sphere can set up some noises when it fails.
Craiglxviii
Cambs UK
With the others, it sounds ABC-ey. The pump is that way, I seem to recall the fuel pump is integrated into the tank.
Will Barber
Will Barber
Cheshire
Okay thank you guys, will report back.
Flyinspanner
Ruislip
Rear ABC sphere may have gone. -but near impossible to diagnose remotely (though it sounds like when my pulsation damper went- sphere, if so worth a flush, new filter, and refill)
Did you get any dash warning pop up, even if only transitory?
Look at your fluid, is it clear green?
Is the level correct?
Has ABC fluid ever been changed?
Does the ride seem at all more wallowy/ pitchy?
shine
Hampshire
CL 500.W216 + C300 Coupe AMG Line 2018
New pulsation damper fitted on my W216 and the groaning/whining sound now gone.
Will Barber
Will Barber
Cheshire
Guys. By the looks of it, the front accumulator (A2213270215, item 125) seems to be the main item being the main filter for the hydraulic system.
The one for the rear (A2213280015, item 140) is more just a reservoir (swirl chamber) and it's the front one that does the main filtering.
I can get one for just shy of £160 so I'll give that a go and replenish the system with new hydraulic fluid. Very easy to do if it's anything like my old W215 CL... Simply lift the vehicle using a 2-post ramp (all four wheels hanging), remove the damper, fill new damper with fluid, fit the damper then bleed the system.
To bleed I simply add a long flexible hose the the reservoir return hose and stick it in a bucket, then run the engine allowing the old fluid to be dumped in the bucket whilst topping up the reservoir with fresh Pentosin until what comes out of the return hose is clean. I then repeat the process with the car on the ground whilst raising and lowing the ride heights.
I have many litres of Pentosin CHF11S in stock too!
Regards Will
John Laidlaw
Wirral
As I’ve said before Will, no expert on the CL (or anything too much !), but on the 230 (SL) which is pretty similar if I’m correct, the pulsation damper is seperate/small additional sphere. This is the schematic for the SL
Correct John. There are 4 spheres. One per axle, one between pump and valve blocks (this is the one that usually caused noise) and one in the return to the pump.
John Laidlaw
Wirral
Yip, it was this I had been ‘hoping’ for (blind hope as it happened ) when it was in fact my pump giving up. Never mind, all in the past....:p
Will Barber
Will Barber
Cheshire
Okay thanks guys, just got the number in case anyone else requires one:
Pulsation damper: 0004660400
Cost £150 inc. vat
John Laidlaw
Wirral
Yip don’t go buying it yet though until you’ve had the diagnostic....
Will Barber
Will Barber
Cheshire
Done the diagnostics already, nothing comes up. However, after being reminded by you knowledgeable guys, the scenario is exactly the same as it was for my old W215 CL500, so I'm 99.9% sure this will cure the problem. Even if it doesn't, at least I know this has been replaced!
Regards Will
Flyinspanner
Ruislip
The sphere is like a two part ball, with a diaphragm across the centre.
During manufacture, the ‘blind’ end is given some nominal pressure and the pentosin fluid in your system then acts on the other side of the diaphragm. (This allows the system to cope with pressure changes in the pipes as the dampers move up and down - if not the pipes could simply burst, or seals blow)
The spheres are not filters. Filter is on the reservoir.
Same system below.
https://www.benzworld.org/forums/r230-sl-class/1899049-abc-fluid-filter-change-diy.html
Flyinspanner
Ruislip
I know that MB upgraded the filter from 10micron to 3micron around 2008/9, but wonder if anyone has added anything like this aftermarket inline filter?
http://www.brrperformance.com/blog/?p=3777
What do the those of you with lots of experience think?
Worth it for boots and braces approach?
This why the level drops when the diaphragm fails - the extra volume that was gas behind the diaphragm is replaced by fluid that can only come from the reservoir.
Will Barber
Will Barber
Cheshire
  • #19
Guys. I've just been on the phone to the main dealer and they say there is no filter listed for the reservoir on this model (2012 W216 CL500) o_O
I find that a bit odd..... Can anyone shed any light on this, and maybe have a part number?
The filter A0031846101 as fitted to the W215 is not listed for fitment to my later W216. Surely there must be something there to change.
Thanks, Will
John Laidlaw
Wirral
Find that hard to believe ? Wouldn’t have a magnetic filter would it by any chance?
The normal filters were changed/upgraded to 3 micron at some point
