What turns off boot lights in 07 E class W211
mercmancdi
templepatrick - co antrim
www.schnauzersinireland.com
maybe this has been answered before, sorry I can’t find answers,
How or what turns off boot lights on 07 E class W211.
I have found when changing the bulbs to led that I have a bad connection as by moving wires on the light up in the boot lid I can bring lights on and wiggle again to knock off , so going to take cover off ,but first I can’t see how the lights are turned off when boot is closed. There is nothing on the bottom
catch that I can see.
Any small black push buttons on the boot lid surround ?
mercmancdi
mercmancdi
No can’t find anything. I am going to
remove boot lid lining , wherever the fault is it’s close to the we centre light on the boot lid. It’s just they don’t appear to go off once they are on and go off when I wiggle that we light
Probably the microswitch in the latch!
ZZZZ
Probably near the emergency manual override switch in the boot lock (often red plastic sliding thingy), as this normally turns the boot light on/off too.
mercmancdi
mercmancdi
I don’t remember seeing any red panel. Will have to recheck. Thanks.
ZZZZ
I have one in my A200, and there definitely was a similar one in the GLK350 (X204).
It's a tiny sliding switch, accessible (just) from the inside.
mercmancdi
mercmancdi
No red item. But it is connected to the
catch , I took mine apart and now it does not work even when I wiggle it.
Lol. The switch is the problem ok
But I can’t see where it comes off the latch , so does this mean you have to buy the whole thing ? I have few photos.
Yes, its going to be one unit. You may have some luck with electrical contact cleaner.
mercmancdi
mercmancdi
Tried contact cleaner , airline etc
Think it’s gone , when I got the car the boot lid was taking water I had to seal it and drill 2 tiny holes to drive it out , I think the water done the damage. The locking is all good so don’t think I will buy whole unit just for the we boot lights.
mercmancdi
mercmancdi
Anyone know exact fuse number that covers the boot lights ,
I have the the sheet but there’s so many under ambient lights , it’s hard to pinpoint exact fuse for interior boot lights.
07 W211 E320
mercmancdi
mercmancdi
Anyone know if I fit a second hand
complete boot latch will my own keys still remotely lock and unlock the boot
If you change only the latch, yes. The lock cylinder is in the release handle section and stays the same.
mercmancdi
mercmancdi
Thanks so then the remote locking for the boot is not effected.
I would be changing the bottom latch unit , not touching up at the handle or
key barrel.
Hustler
United Kingdom
2003 C200 Kompressor Coupe 1.8L
Just curious, does your dash show the boot is open warning when driving?
I've got a 2003 W203 C-Class and my boot wouldn't open because one of the 3 cables going into the boot latch had come loose from the connector. Managed to sort that with a slight wiggle and chewing gum to keep it in place out and now it opens and closes. Only problem for me now though is my dash still shows that the boot is open even when it's not, so I'm thinking it's an issue inside the latch unit itself.
mercmancdi
mercmancdi
  • #19
No light on my dash the only fault in mine is the boot lights run from it .
There seems to be quite a bit inside
the works attached to the latch ,
I bought a used one in Germany on
eBay they were open to offers I got it for £29 all in.
mercmancdi
mercmancdi
  • #20
Just we up date fitted new ( second hand ) boot catch 15 minutes , working great lights in boot working as they should.
Thank to anyone who advised.
