I have a wiring diagram for the car and all fuses are ok.
I notice that the hazards arn't working also so this makes me think its the flasher relay or ticker. I am not sure if the merc has a relay for this or a small silve ticker unit.
Anyway i have the relay box off in front of me and it looks like STATS diagram but without the C, D and E relays.
Another note. Could the switch in the stalk itself be dodgy? If so that wouldn't affect the hazards also would it?
Any thoughts? feel free to reply right away because i'm out with the car with the laptop on wireless right now
Thanks Tim
07881 787 757 - just in case u know exactly what the prob is and wanna give me a call
They suddenly started working agian,,,, however i notice than sometimes when i turn the on all the lights on the consol flash and needles suddenly drop and settle back again. This doesn;t happed every time.
Can you think what ecu or unit would cause the indicators to cause everything else to flash or fail for a split second?
On Stats relay diagram from before do you know which one that is? Is it actually located in the relay box? From your diagram it's tricky to see which 119 really is.
My fuse box is just like the one in Stats diagram minus the C D and E relays.
I also notice that 119 controls the wipers which may account for the intermittent problem with those also.
Forget the below - i somehow managed it with the help of some fine scissors
Something gives me the idea that it wasn't meant to come out once it goes in. The little clips need to be all open simultaneously. Either a special tool is needed or isn't coming out.... any handy tips?
