Which brake fluid?
Tacho D
Norfolk UK
CLK 230K W208
Hi, I think I am well overdue for a brake fluid change and there are choices between Dot4, Dot4 plus, synthetic, and non synthetic. Any idea which will suit a 2006 CLK? are there any issues with mixing, as I don't know which of those is currently in there.
malcolm E53 AMG
Have a look on the brake reservoir cap the fluid type should be printed on there - no need to put anything other than that in there
DSK
CLS 320 CDI, S350 Bluetec
I’d avoid mixing. If you do, my understanding is it will only be as good as the worst stuff in there.
Tacho D
Tacho D
Norfolk UK
CLK 230K W208
I am looking to flush plenty of the new stuff through the system but not sure if this will get it through the ABS system. The Haynes manual recommends Dot 4 plus.
mioba
Nottingham and Köln
Use a baster to get as much out of the tank as possible then go draining (furthest to nearest) keeping the tank full with fresh juice.
