Will CLK 2007 220CDI have alternator clutch?
Droverunner
West Cambridgeshire
2007 CLK 220 CDi Sport. 2014 S-Max 2.0TDCi.
At 115K mls I'm doing a water pump, tensioner, idler pulleys and aux belt change. I wondered though if I should have an alternator clutch on this car? When I had the aux belt off the other day I noticed the alternator pulley was solid with no clutch action. There is no rattling or noise from the alternator and if it shouldn't have a clutch then no problem... if it should and mine is seized I'll replace it.
Is there any way from looking to know if you have a clutch or not?
If I did find a replacement needed is this tool OK for the job... http://www.ebay.co.uk/itm/22pcs-Alt...683425&hash=item3acf288786:g:wtQAAOSwFnFV~maD
I see there are cheaper tools like this... http://www.ebay.co.uk/itm/Mercedes-...epid=0&hash=item3aec6a704d:g:BGUAAOxykUZTh7Kp but I assume to need something to go up the middle to hold the alternator shaft still??
om613
london
S202 C250TD, S123 240TD
You'll almost certainly have a freewheel pulley.
My 2002 E class did.
I bought a cheap £5 tool and chopped down a TX bit to go through it.
They can be quite tight to crack off...
Droverunner
Droverunner
West Cambridgeshire
Thanks. I'm doing the water pump etc tomorrow and will look at the alt pulley more closely. I think once the plastic cap is prised off the front of the pulley it will be possible to see if it is a clutch type or not.
Re the tool I'll just get the cheap spline thing as I have loads of torx bits I could make fit. I wonder though if anyone knows the exact type I need as they seem to have different amounts of splines.
Droverunner
Droverunner
West Cambridgeshire
Did the water pump and pulleys swap today. Popped the plastic cap off the alt pulley and it's clearly a clutch type that's seized solid so I'll get a pulley and the tool.
Droverunner
Droverunner
West Cambridgeshire
Droverunner
Droverunner
West Cambridgeshire
www.ckinsurance.co.uk
