Wing mirrors facing the wrong way
Iggipoppop
Gloucester
C250 cdi
Hi everyone, I trust you all had a good Xmas and new year!
I've had my Mercedes c class coupe for 3 weeks now and I'm loving it, although I did have a potential issue this morning . . . .
When I went to my frosty car this morning the wing mirrors were facing the wrong way, instead of being folded in they were folded out?!?! I thought they may have been moved by a prankster but in fact they had moved electrically, when I got in and started the car they didn't move, staying facing out, I pressed the button to fold them in and they did exactly that, all the way in, when I pressed the button again they folded back all the way out again! I ended up driving to work with my mirrors folded in and when I got here I tried the button again and this time, on the second press, they moved out to the normal position!
Does anyone know why this would happen and how I can stop it happening again?
The last position they ended up in, before you drove off, was folded out ?
So why did you drive to work with them folded in?
I
Iggipoppop
Gloucester
C250 cdi
When they were out before I drove, they were facing out, as in the glass was facing away from the car, I decided I'd rather have the glass protected on the inside by having them facing in!
Sorry, I may have misunderstood you.
Are we talking about the mirrors folding in, or the actual glass adjustment?
I
Iggipoppop
Gloucester
C250 cdi
The actual/entire mirror, not the adjustment! So normally when I go and unlock the car the folded mirror would move outwards to its usable position, this morning it was already in an unusable position and didn't move once I unlocked the car! It was like the mirrors had been bent backwards!
So they had folded past their normal point?
I
Iggipoppop
Gloucester
C250 cdi
That's right. I assumed they had been moved manually by someone so I manually moved them back in, however they didn't click into position, so I moved them back and they clicked back but still past the normal point!
I would say that they have been vandalised and broken then!
MARK.W
Bournemouth Dorset
E320 cdi 2008
Stance thing is, mine did exactly the same thing this morning. E coupe. I think it must be due to freezing moisture in the mechanism? Now fine.
I
Iggipoppop
Gloucester
C250 cdi
I don't think they've been vandalised because by the time I got to work they returned to their regular and correct position and then when I locked the car they moved in as expected! I wondered if it was something to do with the cold weather and if they move automatically so they don't sieze up or something!
I'm glad I'm not alone on this one, it's just really confusing!!
MARK.W
Bournemouth Dorset
E320 cdi 2008
No not vandals. Mine were tucked in all night, unlocked this morning and opened door they then unfolded way past the normal position. Same as you, all OK now??
I
Iggipoppop
Gloucester
C250 cdi
Yeah I've just driven home from work and they operated as expected, it would be nice to know if this is a feature or a fault really?!
Im sure its a fault, possibly that it cant locate the position of the motor in the cold. What does the manual say?
Could the mirror just need to be set, they should go back to normal again if the mirrors are held, while the set set up again.
I
Iggipoppop
Gloucester
C250 cdi
Haven't found anything of use in the manual, yet! The mirrors are now back to normal and have been ever since my journey to work, it was just the start of the day that caused the issue!
Naraic
2005 CL500.
Is it me...or is this the most confused thread of the year so far?
You fold the mirrors out but drive to work with them folded in but they fold out when you press the button...??? :confused::confused:
School report...could try harder.
Xtractorfan
S class
You are the only one confused... The mirrors actually mirrored themselves in the folding department. So folded back against the wings. or folded 180degrees as opposed to normal 90 degrees. So no confusion there.. unless you were a mirror or a looker on...
180 dgrees from the folded in position...Just in case...
Naraic
2005 CL500.
You see...you've just added to my confusion.
Naraic
2005 CL500.
OK...so how is that even possible? My mirrors cannot go further than straight out...except they are knocked...not driven by the motor.
