2000 s210 lost power lost turbo :/
My car's problem was the electrical turbo actuator. No idea about your car.
Linuus
Linuus
crawley
w210 wagon
  • #22
The actuator on mine is working, did you had to replace for a new turbo??
bob 6600
Audi S8 V10, S210 E320 CDI (R.I.P.)
The turbo on an OM613 is very reliable and very rarely fails.
As mentioned in the thread, it is likely to be another issue, either MAF or EGR which are a lot more common.
Linuus
Linuus
crawley
w210 wagon
  • #24
Yep... Star or Carsoft will do it though.
Could help if you were nearer (have both).
Where are u buddy?!
Linuus
Linuus
crawley
w210 wagon
  • #25
Vacum calve is working too. Will remove the engine comer and check EGR Saturday maybe
Linuus
Linuus
crawley
w210 wagon
  • #26
I agree for some reason I thing EGR will be somehow blocked or not working 100%
Linuus
Linuus
crawley
w210 wagon
  • #27
Ps: the Mass air flow sensor was replaced a few year from what the previous owner said
Linuus
Linuus
crawley
w210 wagon
  • #28
Correct me if I’m wrong, if MAF had a problem the car in idle would struggle to run right?! Because wrong/ no right air info would be calculated.
My car on idle run smooth as ever. On park mode I can rev the car all the way above 3-4k REVs.
Only in D-mode the car won’t REV over 2k.
Which I think some of the exhaust air that goes trough the EGR is not flowing and therefor not triggering turbo to boost the engine.
When pulling the throttle I can see the actuator doing his job, opening and closing. And to finish, because there is no light on the dash means, the EGR is working somehow but maybe obstructed... that’s what i think, I’m not a specialist in the matter :/
But EGR is next to check
I opted for the refurb'd actuator. I wasn't prepared to spend £2500 for a new turbo .... the quote from the local-ish indie
Linuus
Linuus
crawley
w210 wagon
  • #30
Woooow 2.5k.... that’s quite a bill
Linuus
Linuus
crawley
w210 wagon
  • #32
Midlands near Northampton.[/
I see it’s a bit away as you said. I will have a Mercedes specialist checking the issue and doing a Star diagnostic in 2 week. 20min from where I live let’s cross fingers to be something very simple. Anyway, is there any turbo cleaner your guys recommend or using of your engine to get rid of some of the carbon built?!
bob 6600
If the MAF was not a genuine Pierburg one I would change it regardless. You can buy them from reputable sellers rather than MB
Linuus
Linuus
crawley
w210 wagon
  • #34
So guys today. I took the car into the potorway, with tank of diesel and archoil AR6400 foot down. Up and down after 30£ of diesel I have notice the turbo back to life, I don’t know what when wrong.
om613
london
S202 C250TD, S123 240TD
Good news. I doubt it's a permanent fix, though.
Linuus
Linuus
crawley
w210 wagon
  • #36
That’s my concern, I will be taking the car anyway to mercedes specialist to have a diagnostic on Star just to have a full check
Frontstep
T210 320cdi
The turbo shafts gum up if not regularly exercised
om613
london
You mean the VNT mech?
I did see one with real bad pitting on the turbo shaft. It was my mate's car, he's too lazy for oil changes.
Yes these need a regular thrashing! Hard to do, legally...
Linuus
Linuus
crawley
w210 wagon
  • #39
I even though it could have been a blocked injector.
Linuus
Linuus
crawley
w210 wagon
  • #40
Oil changes u mean engine oil change or any specific turbo oil lubricant, sorry for my ignorance :)
www.ckinsurance.co.uk
