2006 A Class central locking problem
pace
Oxford
2003 ML 270 & 2006 A 150 SE
Hi all, I have just realised with horror that the rear near side door on our 2006 A150 will not lock.
Back in the winter when we had the snow the central locking started making a chattering sound when locked with the remote and when the car locked automatically as you drove off.
I hadn’t noticed this happening again until last night when I had to leave the car in a hospital car park. As I locked the car it 'chattered' again, I happened to be stood by the rear near side door and noticed the locking button jumping up and down. It settled in the locked position so instinctively I tried the door handle. To my surprise the door opened. I unlocked and locked again several times and switched the child lock, but nothing I did would make the door lock. All the other door were locked but not this one.
It is obviously a security worry if I cant lock the car so I need to get it sorted ASAP. Is there anything to adjust in the door to solve this problem? or does it need a new locking unit fitted? I guess this part must have become frozen in the winter and stripped a tooth or bent one of the components?
Is this a common problem?
I have sent you all of the details
P
pace
Oxford
Many thanks Malcolm :)
sirlylos
New Registration
Middlesbrough
A-Class A150 Elegance
Hi Malcolm,
We are having the same problem with the chattering central locking, any chance you could send over the document you sent to the OP's email address?
Ours is:
mrlylos@msn.com
Thanks!
Hi Malcolm,
Ours is:
mm
Thanks!
I have sent it :D:D
Rob1989
New Registration
A150
Hi Malcom,
I am also experiencing this problem where the lock is jumping could you forward me the intructions on the fix?
I have a A150
Rob_chapman_1989@hotmail.com
Rob
ianderson
New Registration
Bristol
2005 W169 A180 Automatic
I had the near side rear door lock on my 2005 A Class replaced in February. The first sign of frost this week and it's started bouncing again. Any information or advice you can give would be very gratefully received. Regards, Ian
i.anderson@tesco.net
imaging
New Registration
I am also having this problem with the nearside rear door lock on my 2005 W169 A200. Any chance of emailing the fix?
imaging@yahoo.com
Many thanks in anticipation Malcolm.
John
I have sent them John and welcome
P
pwdavis
This is my first post, I am also having the same problem would be gratefull for any information on this fault. Thank you
Regards
Paul
pwdavisandsonltd@aol.com
Hello Paul and welcome, I have sent 169 info, but if a 168 please say
They have been sent
miffy123
New Registration
Mercedes A class auto 1995
Door Chattering
Hi Malcom
This is my first post. I have the same door chattering problem with both back doors on my A150. Please could you send me the fix and info on the tools needed etc.
Many Thanks
janineapp@hotmail.co.uk
I only have the front door info printed off,it is near enough the same and I have sent it, you can edit out the address and welcome,, if you get stuck ask again please
