, Need to say the information on the posters car is not there ,so some dont know what car he has ..Every auto i have had will hold on the hill . So revs are to low or engine is not up to peak peformance .
[QUOTE="DREAMER NO2, post: 1529059, member: 68829" .....
Every auto i have had will hold on the hill . So revs are to low or engine is not up to peak peformance .[/QUOTE]
if the engine is idling at the correct speed and it rolls down the hill, its a steep hill or the box is worn
for the the one where he can't find HOLD function... drive the car, brake to a halt and then try pressing the brake pedal down till it touches Australia, just before you reach this point HOLD comes up on the dash.... as you go to pull away press the accelerator more firmly than you want the car shudders and you might get a small noise as the "hand brake" frees off
or you come to a halt and leave your foot just resting on the brake pedal and gently pull away when the lights change...
either way the brake lights irritate the guy behind you
Mercedes-Benz Servicing, repairs, engine and diagnostics Wayne Gates - Mercedes-Benz, Unit F3, Phoenix Industrial Estate, Rosslyn Crescent, Harrow, Middlesex, HA1 2SP Tel: 020 8863 9233 Established for 20 years all vehicles washed and vacuumed.
