MrTash
- Jul 10, 2013
- Location
- Andover,Hampshire UK
- C220 CDi W204 2011.
I know this all relates to an old posting but just to confirm for anyone having the same problems I'll bet 99.9% it's the Vaccum Pressure Converter valve located in the water pump area. I've provided a photo of the item you will be looking for. I had this issue over a year ago and after changing a couple of items that were suggested it turned out to be this valve as at some point the last owner had glued one of the connectors that was damaged and was leaking allowing a loss of vaccum. Since I changed this valve I've not had any further power loss issues so just something to think about if you should get such problems yourselves. One other point I'd make is don't get the Merc part just obtain the "Febi Bilstein" one as they make them for Mercedes anyway and at £19 a lot cheaper too and does the same job. So don't go paying something like £50 just for the Mercedes name its not worth doing so both parts are exactly the same item just one is cheaper than the other and work just as well.Quick question. A few months back I had random 'loss of power/turbo' symptoms. Several on these forums suggested the MAF sensor. As it didn't happen again I never got it checked out, until a dealer service last week, when I mentioned it and got it checked out.
Apparently the computer logged a 'boost pressure system' error. They'd checked everything out and could not find a problem. As it's only happened twice since I've had it (6 months?) they asked me to monitor - and let them know if it happens again.
Yesterday it did. So, it's back in there again today.
Apparently 'boost pressure system error' may not be anything to do with the MAF, and they're investigating it thoroughly today.
Question is:- Is this still likely to be the MAF? Luckily it's all under warranty ... but I hope this isn't going to be a long drawn-out "don't know what it is - keep taking it away and let us know if it continues" exercise.
Symptoms are: loss of power, as if turbo fails (foot to floor and no acceleration). Turn off ignition, restart 5 mins later and back to normal. No warning lights or 'malfunction' displayed on the dash. The only fault logged had to be read via an error-code-reader.
Any ideas?
