MrTash
- Jul 10, 2013
- Location
- Andover,Hampshire UK
- C220 CDi W204 2011.
Not sure I can only comment on my own car as to what the cause was. If you have the same solenoid on your car just try putting a bit of WD40 down the vacuum ports and let it sock in and see what happens. If it clears the problem then you have your answer. Good luck and let us know if it sorts your issues.Hi Would this be the same issue on a 646engine?
