Costs associated with S320
R
romik
Ipswich
S320 CDI/2005/3.2
  • #61
Thank you very much. One day I hope to upgrade it to a newer one, that depends on ROI this one generates. Just reading the manual, so many buttons...
R
romik
Ipswich
S320 CDI/2005/3.2
  • #62
Is regular diesel Ok for this engine or does it require something like V power?
tode
NW FRANCE
S350 btec 2011
It should be OK: just try to avoid buying diesel after a delivery (the muck in the tanks gets stirred up).
M6AJJ
Norfolk. UK
v222 2014 350
Just ordinary diesel works fine, at least that is all I use.
R
romik
Ipswich
S320 CDI/2005/3.2
  • #65
Two questions: none of the cigarette lighters work, can't find the fuse chart in the manual.
Secondly, quite a bit of oil on top of engine cover. Any ideas what caused that?
image here: www.tinypic.com/r/2e3sf2t/6
The fuse chart is in with the tools or folded up in a fuse box, it will be fuses for the lighters
R
romik
Ipswich
S320 CDI/2005/3.2
  • #67
I love this car, customers praise the ride & refinement all the time.
R
romik
Ipswich
S320 CDI/2005/3.2
  • #69
What is a good brand for tyres for s320? I am looking for all season tyres.
Xtractorfan
S class
Looks like someone has been adding oil from a 4 or 5lt can without using a funnel shaped filler.. and didn't tidy up afterwards
R
romik
Ipswich
S320 CDI/2005/3.2
  • #71
I noticed that when driving from cold start in the mornings gearbox doesn't change at same low revs as when engine at normal level, it keeps it in low gears until revs reachs 2500. Perhaps that's normal.
whitenemesis
CLS55 AMG '05
It is normal and used to help bring the CATs up to temp more quickly
R
romik
Ipswich
S320 CDI/2005/3.2
  • #73
Thank you. One more question - is it Ok to switch off the engine in neutral gear and start in neutral?
Naraic
2005 CL500.
Yes...no problem at all.
R
romik
Ipswich
S320 CDI/2005/3.2
  • #75
Developed a knocking type sound coming from the front when driving at slow to moderate speeds (uneven surfaces). What are the possible issues here?
whitenemesis
CLS55 AMG '05
Worn ball joints, or other suspension joints
whitenemesis
CLS55 AMG '05
Our indies would be better informed to answer, Alex Crow is over your side of the country
R
romik
Ipswich
S320 CDI/2005/3.2
  • #79
I know, I am taking it there for a service in Jan, but he is fully booked to do this job and it's urgent. Don't want to be quoted stupid prices when I take it in tomorrow to a local garage.
R
romik
Ipswich
S320 CDI/2005/3.2
  • #80
Had it looked at, it's NS front back suspension arm ball joint.
