Costs associated with S320
Cardinal Biggles
Suffolk
CLS 320 (09) W219; C220D (07) W204
I know, I am taking it there for a service in Jan, but he is fully booked to do this job and it's urgent. Don't want to be quoted stupid prices when I take it in tomorrow to a local garage.
I had mine done on my CLS by the main dealer. Although mine (2 x front) were done under warranty. iirc it would have cost me £220 for both sides (always replace in pairs). So Id assume £150-£160 from a decent non MB garage using genuine MB parts. x2 if you are doing all four wheels.
R
romik
Ipswich
S320 CDI/2005/3.2
  • #82
Thank you for the info.
The more I drive the car listening to the noise the more I doubt it is to do with ball joint. Firstly, it makes the noise no matter if it is left or right wheel that goes over uneven surface. The noise seems to come from underneath my feet area, so doesn't suggest N/S problem. The noise seems to be as if something has come loose, like a little drum roll :) You can probably tell I am not a mechanic :)
R
romik
Ipswich
S320 CDI/2005/3.2
  • #83
I was driving and noticed that suspension got pretty stiff, every bump seemed like a massive pot hole. Then noticed that both buttons that work suspension were lit up, couldn't disable them whilst engine was running. Had to switch engine off and back on to get suspension back to normal. Driving conditions were not any different, yet for some reason computer did that. No malfunction was showing on screen.
R
romik
Ipswich
S320 CDI/2005/3.2
  • #84
Guys thank you for recommending Alex Crow, been there twice and genuinely happy with Alex's professionalism.
Question: when ignition is turned on I hear some sort of buzzing noise near rear view mirror. Due to technical issues of my PDA I am having to keep ignition key on a lot whilst waiting for a booking, with that noise being there and dash lighting up does it drain battery much?
The buzzing with be the heater fan sensor,it should not buzz but doing no harm, a touch of oil and it should be fine.
Leaving it turned on will flatten the battery quite quickly
R
romik
Ipswich
S320 CDI/2005/3.2
  • #86
Front suspension gone very squeaky, sounds like old springs. I am miles away from home, should I call breakdown?
SteveX
I wouldn't have thought so is it's just a squeek? Does it drive ok?
R
romik
Ipswich
S320 CDI/2005/3.2
  • #88
So far driving fine, no squeak too. Weird
R
romik
Ipswich
S320 CDI/2005/3.2
  • #89
Got back home Ok, the noise is back though. Massive squeaks when turning left and on uneven surfaces, noise also there when pressing on front end. Will have to call Alex asap :/
C16RKC
Wisbech
www.youtube.com
2003 CL500, 2007 S320CDi
Oh dear... hope it's nothing serious?
Did you get the knocking at the front sorted before, perhaps it's the same issue surfacing again?
R
romik
Ipswich
S320 CDI/2005/3.2
  • #91
Nearside arm and ball joints being replaced.
R
romik
Ipswich
S320 CDI/2005/3.2
  • #92
Xenons upgrade
Just wondering how much would it cost to get Xenon lights on a w220 (not at main dealer).
tode
NW FRANCE
S350 btec 2011
If I could give a bit of (personal) advice:
You've got yourself a nice car, although not the latest model.
Look after it, keep it clean and well-maintained, but I wouldn't bother adding accessories or doing mods - you won't get your money back at resale, and I don't think your customers will see any difference.
If your business works well, then in say a year or two think about getting a 221 with the options you're thinking about: you'll get them virtually free.
Good luck with the business. :D
R
romik
Ipswich
S320 CDI/2005/3.2
  • #94
I appreciate what you have said, thank you. The main reason I was considering to upgrade the lights is to be able to see better at night, I find current bulbs are not bright enough, I do quite a bit of driving in the countryside, obviously not well lit at all.
whitenemesis
CLS55 AMG '05
Headlamp units are approx £1k each, not sure what extra you'll need to complete the retro-fit but It's not going to be cheap!
R
romik
Ipswich
S320 CDI/2005/3.2
  • #96
Ok, too expensive in that case. Thanks!
tode
NW FRANCE
S350 btec 2011
What bulbs have you got at the moment?
There are quite a few threads about halogen bulbs on the site.
R
romik
Ipswich
S320 CDI/2005/3.2
  • #98
Just factory Halogen ones.
ThinkPad
London
E W212; C W204
There are ways of doing this a lot cheaper. Search eBay for HID kits. You will need to do your own research regarding the legalities and quality of product. I have done it in the past, for less than £100. Main thing with these is that you will need to ensure the beam patten is not out, so that it blinds other drivers, which of course is dangerous.
R
romik
Ipswich
S320 CDI/2005/3.2
  • #100
That's what I was thinking of actually. Will look into it.
www.W140.co.uk&www.r129.co
