E Class diesel,
edgeshat
cumbria
slk 350
Ive read on many sites regaurding the age old concern of diesel's. I'm hoping someone can shed some light, So here's my dilema.
I want to change to a E class (hoping 350) diesel, But i only travel about 20 miles a day for work on a faily fast drive (50 / 70) mph, And about once a week do about 40 miles with 70mph driving. So will i be safe with the "DPF" issue, As far as i can understand the Regen takes place after about 30 mins of driving so i should be o'k regaurding that, But it's always better i find asking the people that have the cars in question "rite" !!!
Anyhow, Many thank's for any info.
malcolm E53 AMG
Welcome!
You do more miles than I do in my E350cdi so I wouldn’t worry about it and I don’t have any DPF problems. The OM642 V6 diesel warms up very quickly so that helps a lot, unless it’s very cold the engine is fully warm in 4 miles so your commute is about right, if a regen takes place and you stop the engine it will recommence as soon as the engine is up to temperature again. It’s fair to say that MB seem to have designed the DPF system well with few problems listed on here.
Hope you soon find the right car, buy the 265bhp version, early production cars were 231bhp
Ps they do suffer thermostat failure, mine did at 70k miles, if this happens you need to replace ASAP
sonic
Staffordshire
E350CDI, SLC250d, FJR 1300
I have the E350CDI the 265 BHP version, its a great car. The heater is warm by the end of the street.
Retired now so I am doing the odd short journey, when I was working it was 10 miles to my workplace.
Never had any problems at all.
edgeshat
edgeshat
cumbria
slk 350
Many thank's all,,,, hoping to start looking soon, just in time for the summer here,,, lol ;) will keep posted and pics too
weds
Chatham
2011 E class Estate 350cd, Porsche 928 S4
I have the same engine but mine seems to take some time to warm up, might have to look at changing the thermostat..
Ricardo_e220
Newcastle upon Tyne
R170 SLK230k 1999
I would check but my s211 clearly had an electric heater fitted as was warm by the end of my street...the only car I’ve ever had that was like this...
Other than that the miles are ok for a dpf regen on the longer journey at least... if any lights do come on run that at a lower max gear
Yes the 211 have a PTC heating element in the dash for warm air. Older cars use a heater booster to heat the engine coolant and they always fail early.
V6Matty
Newark, Nottinghamshire
that's the one thing I really miss in the 212 compared to the 211, I'm deciding if I should search from a pre heater or not, just need part numbers I guess
You can fit a webasto. They can be had from about £400 and give instant heat, available from a remote.
V6Matty
Thanks Alex, that was the name I was trying to think of, although I'm sure there must be a OEM for the Mercedes kit, thinking second hand on German EBay or similar
The diesel powered heater boosters that MB fit Oem are webasto as well but they are CAN switched and are turned on/off when the car programs them to. The normal webastos come with a remote and can be programmed with a timer.
MB also offer a timer for their oem version but I don't think it was available in the uk.
sonic
Staffordshire
The pre 2010 cars had a really useful function where you could leave the heater fan running for an hour after you stopped.
Very useful on a cold night, when you came back to the car it wasn't frosted over.
Craiglxviii
Cambs UK
Yup. REST is specific though dependent on engine or grade levels.
Jimbo1959
Ayrshire
VW Scirocco. The Quattro, E350 CDi Blue Efficiency Sport Coupe, now both gone
I haven't come across that function on my '59 plate E350 CDi, tell me more, please!
V6Matty
Should be a button on heater consol tat says REST Jim, if your car has warmed up and you switch off you can hit tht button and it uses the residual engine heat to warm the cabin, obviously if the car isn't warm before it doesn't work. As Craig mentioned abov though it's not a standard system but tends to come with te bigger engines lie the 350
Jimbo1959
Ayrshire
Mine is the 350, but sadly no”rest” button. Oh well, I’m accustomed to using the scraper while she de-mists.
