ESP warning message
ajlsl600
france
There is no oil dipstick. Depending on gearbox there will be a tube with a cap or nothing at all (in which case a check is a top up from below).
If you have the dipstick tube (with either a black or red cap) you need to buy the dipstick as a tool .It does not remain on the tube afterwards!
Dipsticks can be found on eBay amongst other places.
great aint it. a basic maintenance tool as an optional extra !!! rad caps next ? clever boys dem benz boys...........
N
nick stock
c 320 cdi 2006 3.00 turbo diesel
  • #24
Weird now everything alright all lights out goes like a train as usual
N
nick stock
  • #28
How do I do that?
oigle
members.optusnet.com.au
Suggest you contact one of the indi's. It is simple. It involves removal of the electrical connection to your swirlflap motor and inserting a 5 ohm (I think) resistor between the two terminals on the wiring - not the motor. Leave the connection disconnected and tape it up. This stops the motor working but fools the ecu into thinking it is.
N
nick stock
  • #30
Thanks I'll get them to do it
It's a 4.7k ohm resistor (20p ish ?) that is put into the middle 2 terminals of the supply to the inlet port motor , which is below the black batwing ( air intake to the turbo) . It's very easy to do , my car has one in now after some limp mode issues a few months ago .
Doug1234
Bedfordshire uk
1997 w210 e300td
Just reading through this thread and would like to throw this into the mix.
I have a 06 Jeep grand cherokee with the 3.0 om642 in it and 722.6 gearbox and thats about all maybe except some software that is Mercedes based.
Ok so I removed rear light units and fitted canbus led’s replacing the reverse bulbs as stock bulbs are dire. After a few days I get esp/bas light and traction control light ping up , but only when side or head lights in use.
Icarsoft bcc2 tells me its p0703 brake switch b circuit / generic which means bad brake switch or wiring / ground / bad bulb.
The fault is random (but always need side or head lights on for it to happen) and every time I exceed 50mph it pings up main engine light... only the one code still though p0703. The esp /bas and traction will be gone upon restart unless main engine mil is illuminated , which I think is because a bad brake switch could cause the torque converter not to unlock and cause engine obviously to stall if I slowed to a complete stop
Fitted new switch mid week only for fault to remain.
Found the cause this afternoon ,now passenger side earth was grubby and had a crimped connection so I thought thats the cause and cleaned it up and set about cleaning bulb holder connections ... until removing one combined brake/ side lightbulb (3157) I find the smaller of the two filaments has come adrift off its post and is laying over on the other filaments post ... hence why fault only occurred when side/ headlights on.
More memorable was the Jeep turn itself off after only running for about 15 seconds Thursday morning ,dash lit up and a nice big red lightning bolt kind off warning light greeted me.
Turn key to restart and it just keeps whirring over until I remove key (same as Mercedes in that you touch and let go of key). I cannot hear intank lift pump running so I read codes and get intake manifold / turbo / egr / and just about everything but the main is fuel rail system pressure low.
So search the internet , lift pump fuse is ok ?. Found this post
https://www.jeepforum.com/forum/f67/stalled-2007-crd-3-0l-2353121/
So having fitted the resistor to my swirl plug a few months before I check it out and it has been touching the engine casing and this has blown fuse 16 and ASD (auto shut down relay had stopped car.
My fault as being a clever type I cut 3 fingers off some disposable gloves and covered resistor and plug with them and cable tied in place... the glove fingers had decomposed as they do and the terminal block which I jammed vertical was now laying over on its side . New resistor and fuse 16 replaced and all codes cleared and all ok since.
Good tip on taping up the resistor buddy . The fuse is F44 on the facelift W211 (Just in case an MB owner is reading this ) in the engine bay .
N
nick stock
  • #34
