Help cl600 is Kaput
Stuartph600
Cl600
  • #61
Today’s work
Throttle body wiring checked for continuity
Did another make shift ecu reset and throttle body adaption and got car running and up to temp
1st video is car running
2nd video is throttle body make shift adaption with engine at 80c engine is off but you hear throttle body working
That throttle body doesn't sound too healthy.
How was the wiring?
Stuartph600
Cl600
  • #64
This arrived in the post today
Only painful part in fitting looks like getting access to the knock sensors
Yes they need the turbos to come off I believe.
Just cut the loom where the connectors go into the knock sensor wire and solder/heatshrink.
For purposes of testing you won't need knock sensors.
If the car runs with the new loom then you know the problem was that and can then look into reconnecting the wiring. If not there's no point.
Stuartph600
Cl600
  • #71
So.......
At the moment car is starting up ok and not misfiring or bad throttle body issue
But
Getting fault code P2003 secondary air injection fault
Possible I've upset the vacuum line to it or relay issue ?
ABS light on but only getting fault code C1540 and C1540-008 component B24/15 Rotary speed and lateral sensor
Is it a possible drive to adapt to get ABS light to go out?
But guess could be wheel speed sensor which my icarsoft won't deal with
New loom not fitted yet......
ABS may reset after the car gets to about 8km/h as it recalibrates itself.
So.......
But
Check the actuation valves at the front of the engine, they have the Vac lines going to them from the changeover valve on the back left valve cover. (not the divert air one just below it). Its easy to break the brittle plastic barbs off them..... Secondary air can be coded out if its a pain.
Stuartph600
Cl600
  • #74
Ah that sounds good , a little drive next week once the snows gone me thinks
Stuartph600
Cl600
  • #75
I did plugs and valve cover that side so guess i must of upset something
Stuartph600
Cl600
  • #76
Todays Work
Checked vac lines for secondary air , replaced some and make good fitting on vac pump
Took car for a 10 minute drive , ABS light did not go out
Checked codes after drive secondary air fault still present but no light on dash
Re started car and then....... intermittent spikes of revs without touching throttle pedal
Then ESP fault and misfiring again
P202E C1041 P2042
Plug code reader in i notice my moisture trap behind passenger seat had gone over dumping sticky fluid all under passenger seat
Fluid mopped up but notice it has gone down air vent and under carpet all way to front of the seat
Whats under the seat that could be affected
Codes cleared and i fitted one of my spare throttle pedals
Ran ok for 5 mins
Do you have any of those codes from a MB star machine?
What is giving you those codes?
Nothing under either seat that would give running problems, seat controllers etc live under there.
What is this water leak you have?
Stuartph600
Cl600
  • #78
Just Closing this thread down now
Towel thrown in
Thank you to everyone who helped
Stuart
Towel thrown in
Stuart
Sorry to hear Stuart, have you taken the car to a garage? Be good to hear of the outcome.
Stuartph600
Cl600
  • #80
No its not been to a garage , even if it was fixed it would still be going , urgent need for a running car with 4 doors and 4x4 now
Thanks for you're help
www.ckinsurance.co.uk
