How to - Decat a W210 E320 CDI
Hi all
I recently de-catted my w210 to try and resolve a hissing on boost. It didnt, but Im left with a nicer exhaust note :)
The guide is posted on my side here but I have included it below so it can be put in the DIY section :)
I have recently been thinking of removing the Catalytic converter on my Mercedes E320 CDI W210. Primarily I wanted it for the sound, but additionally, I have a hissing on boost, and I had been advised by a good Mercedes Tech, that this can sometimes be due to a blocked pre-cat (after I had checked for boost leaks, of which I found none). So I set to work removing the cat. Note, this process is similar on most cars. There is no worry about MOT testing as diesels are only tested on smoke output and not hydrocarbons and CO2, which is what a cat affects.
(also note, I had previously removed the backbox to install a straight pipe)
Step 1 - Jack the car up, and place it on axle stands:
I drove mine half onto the curb, and jacked the other side up to get a bit more space (naughty I know but meh)
Step 2 - Remove the bolts on the centre clamps on the exhaust. This isnt needed if you are just doing a pre-cat removal, but as I had to repair one of my exhaust tips I removed the whole system anyway.
Step 3
To get to the Primary cat, we need to remove the air box, Firstly remove the engine covers, then remove the primary air filter cover and unit (it pulls off from the rubber mounts that are bolted to the engine block.
Ignore my crappy EGR-Shunt wiring, One day I will tidy it up!. Remove the air filter cover, MAF connector and unbolt the air pipe that goes to the turbo from the side:
Step 4
Remove the air intake pipe that goes from the grill area to the filter.
With the air box removed:
You will be presented with this:
Step 5
Un bolt the bolt on the exhaust clamp and expand the clamp and place to one side:
Also, unbolt the mounting bolt that hold the cat there, This was quite rusted on mine, I had to get out the impact wrench
There is a clamp on the underside of the cat, where it joins the secondary cat pipe, I didnt take pictures of this, but all that is needed is to compress one side of the clamp, and then press the clip out of the clamp with a flat head screwdriver, The reverse is true to fit it.
Step 6
With the cat removed, Its now time to break the cat up into pieces and empty the cat. I used a hammer and chisel to break it up and shook it. I also rinsed out the inside to ensure there weren't any bits floating around in there.
You can just about the see the cell structure in this picture:
Afterwards, just a nice space:
Step 7 - Re-install the cat!
Its basically the reverse of the removal, ensure that all bolts are done up, it may be beneficial to grease the flanges slightly (but I didnt).
Here is the sound of mine after the De-CAT
[YOUTUBE]o1naPQBWB_I[/YOUTUBE]
You also get a little bit of a turbo hiss when you let off the accelerator. Can be heard at the end of the video.
Unfortunately my hissing is still there, so there is still a boost leak somewhere :)
  • Moderator
  • #2
Can a mod move this to DIY? If its worthy of course!
Very nice and thanks :D
  • Moderator
Many thanks :)
Miffy
Bromley, London
CLK 320 CAB Elegance C208
your IL6 sounds more of a man than my v6 :( I cant believe a cdi can sound and move like that
Naraic
2005 CL500.
Is it much more noisy inside the car?
  • Moderator
It is a peach of an engine :) Mines is remapped and I must admit does sound good. Im sure yours could sound pretty good with a straight pipe :)
  • Moderator
No more than when I took the backbox out. The sound insulation is so good that its not really noticeable, especially on partial throttle, just a little burbling sound .
Naraic
2005 CL500.
Remapped, no back box, no primary cat (you kept the secondarys I presume), the EGR shunt, no sign of black death previously...the car's a good'un.
OT: When you did the shunt, did you clean the egr first?
  • Moderator
Indeed, I do still have the secondary cats, just because they are harder to remove :)
I did have leaking injector seals and a bad injector bolt thread that had to be helicoiled, and lots of very bad rust and a rear diff that went, but the engine is a good one! :)
  • Moderator
I did not, couldn't be bothered with dismantling the whole intake to clean it. I may run some egr cleaner through the intake at one point to try and clean it, but im not sure I need it.
Naraic
2005 CL500.
So, you simply disconnected the vacuum thingy, wired in the shunt...and hey presto?
  • Moderator
I left the vaccum line connected, otherwise there would be a vaccum leak, but I could have disconnected it and plugged it with a bolt.
Wired in the shunt, and unplugged the cable from the egr transducer and bobs your uncle!
My mums also has an EGR fault now (grrrr) so will be doing the same on hers, using the CDI3 mod though.
Naraic
2005 CL500.
Would I need the CD13 mod?
  • Moderator
No yours is a CDI2 engine, same as mine. My mums is a w211 220cdi, so newer engine.
toby1
West Berkshire
Many thanks.
My posts in the "Disabling EGR" thread may/may not be of help. I've since removed my shunt pending further investigation into the underlying cause of mega dark smoke under load.
Stokie
New Registration
Stoke
w210/2002/220cdi
Hi thanks for the info, how long did the pre-cat removal take as I am going to attempt this on my E220 cdi this weekend to try and cure a loud howling noise coming from the exhaust area. Also just checking that it should be OK to do regards getting it through MOT as mines due soon?
  • Moderator
  • #19
It took me about an hour, but I would set aside 2 hours if you haven't worked on the exhaust system before. A relatively simple job all in all. Just takes a while to take all the engine covers off etc.
Yup, no problems with the MOT, They only test smoke output, which the cat does not affect.
XPS420
Aldershot
W210 E320 CDI
What an Awesome How to!
I did this to my car today and this tutorial made it so simple!! Only downside is i can smell diesel fumes inside the car.
