Nearly burnt a 3mm hole in wheel arch liner .. best product to fill it?
John Laidlaw
Wirral
Land Rover Discovery 4
Use your finger?
Sorry! But as above (although Polypropylene is not at all the same family as Polythene )- Milk bottles and such are PET so you'd be better with an old shirt packet wrapper or something like that, or as you say the old bonnet catch....
AMGeed
Poole, Dorset
S204 C180K
2 Pages!
[/IMG]
Xtractorfan
S class
The worrying thing is you measured it... sillycone is the stuff ...
Submariner1
Submariner1
Windsor Berkshire
CL500 2009 5.5
  • #28
Araldite seems to have stuck well.
Wether it stays when it flexes who knows.
But filled the dented part
So job done
flowrider
SL500 (R230)
Black silicone sealant would have been better than Araldite IMO or do nothing.
mercmancdi
templepatrick - co antrim
www.schnauzersinireland.com
2009 E250 cdi 08 cls320 cdi ,2007 e280 cdi '2005 E 280 CDI ,VW TOUAREG ,JAGUAR S AND xTO NAME A FEW
Unibond outdoor extreme in black around £5 , and if possible ( although it might be over doing it ) put couple of tiny screws in leavening the heads out few mm to give whatever you use something to catch on .
Naraic
2005 CL500.
Always the first to get bitchy .... ;)
Banality at it's best.
And then you ignore the "advice". Can't wait to see the pics once you have sanded it down and 2k painted it.
Submariner1
Submariner1
Windsor Berkshire
CL500 2009 5.5
  • #35
Didnt ignore the comments, just picked the best (based in advice) stuff I had handy .... as the wheel was off and I needed the good weather to finish the derusting.
If it fails, then I can rely on the useful comments, and go and buy something reccomended.
Imo when gluing these weird plastics its very useful to know what has definitely worked for some people.
Because if it fails to bond then you often have to waste time removing the failed product.
Anyway grateful to all those who posted useful stuff.
Paul1948
Bournemouth
S320 CDI 2003
Why not use the correct thing as used alll over all cars...polyurathane liquid rubber such as Sikaflex in tubes like silicon, available from all marine agents if not available from your local motor factors, builders mechants also stock iit as iit is fully paintable.
om613
london
S202 C250TD, S123 240TD
MB under trays are rubbish anyway, for DIY. A right PITA to remove, drops all sorts of oily crap on you.
Why not take the 'terminally damage' thing down the tip, then you can see if any real issues develop?
An under tray will conceal a leaking gearbox pilot bush, for example.
